EX1 Settings - Timecode at DVinfo.net
Convergent Design Odyssey
Old October 18th, 2010, 11:09 AM   #1
Can someone tell me if the EX1 SDI output signal had embedded timecode or should I use the Nanoflash's "Internal" timecode setting ?
Also, as long as I'm not interested in recording Interlaced, can I leave the PSP to PROG on when switching between recording in 720p60 and 1080p30 ?
Thanks.
Eric Savetsky is offline   Reply With Quote
Old October 18th, 2010, 12:59 PM   #2
Dear Eric,
The Sony EX1/EX3/PMW-320/PDW-350 and other cameras output timecode embedded in the HD-SDI output stream.
As such, the System|Timecode setting should be set to Embedded for most applications.
Yes, you can leave the Video|Record PSF>Prog(ressive) setting checked under the conditions you outlined.
Just check the bottom line of the screen and ensure that it matches your camera settings.
Dan Keaton
Augusta Georgia
Old October 18th, 2010, 02:15 PM   #3
Thanks for the quick reply Dan. I'm off to film white sharks with my new Nanoflash !!!!
