#16 |
Re: HDX900 + nanoFlash - Major Announcement
Dan: Is there still a 1 sec TC offset needed on the NanoFlash in order to match TC from the NanoFlash to the recorded tape?
Thanks |
#17 |
Dear Dusty,
For the HDX900, we recommend a setting of 1, which is 1 second, in the System|Timecode|Trigger Delay menu item. This value has proven to be useful. This ensures that the timecode values written on tape, for each frame, will match the timecode values saved in the our file for each frame. The 1 second value allows the nanoFlash to ignore the false timecode values from the HDX900 for 1 second prior to starting to record in the nanoFlash. The HDX900 puts out false timecode values pver HD-SDI when it repositions the tape prior to it starting to record actual frames. I will be happy to provide even more detail if desired.
Dan Keaton Augusta Georgia |
#18 |
Thanks Dan. I have four cameras that I've been using with the NanoFlash and all are different systems. Each one has it's own NanoFlash setup. Just wanted to be sure all was the same with the HDX settings.
Best |
#19 |
Bump to bring this to the top
