No SDI Sig on bars setting - Page 2 at DVinfo.net
Convergent Design Odyssey
Old September 11th, 2010, 11:32 AM   #16
Dan and Robin:
As I mentioned earlier, I kind of remember running across this problem before. I'm on a project with the F-900 and won't have access to my HDX-900 for awhile, but I'm curious if in E to E mode connected to the HDX-900 with Color Bars and Supers on, if the Bars even show up on the thru put of the NanoFlash to a monitor?
Dusty Powers is offline   Reply With Quote
Old September 11th, 2010, 12:29 PM   #17
Dear Dusty,
In "E to E" mode, the HD-SDI Input is sent to the HD-SDI output, without any processing.
This is an ultra-low latency process. The input goes to the output about a microsecond later.
We do not do any processing of the input signal before we send it to the output.
It is, however, re-generated and reclocked. Thus any weaknesses in the input signal, such as a low level or jitter will be corrected.
However, since we can not sync to a signal, with Pulldown Removal Checked, one that is both 24p and 30p, then no, you may not see the Color Bars on the monitor with the Camera Id set to Bars. When it is set to Off, you should see the Color Bars.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
