After Effects CS5 and nanoFlash at DVinfo.net
Convergent Design Odyssey
Old August 24th, 2010, 06:48 PM   #1
So I just got my nanoFlash, recorded some test footage into MOV format, couldn't import it into Premiere CS5 or After Effects CS5. Downloaded the MainConcept Premiere CS5 plugin and re-recorded my footage into MXF format and was able to import it into Premiere CS5 without a hitch. However when I went to "Replace with After Effects Composition" After Effects CS5 crashed. Should I export the footage to an uncompressed 1080p AVI or is there a better workflow? I touch up every frame of my projects in After Effects with tons of filters so it is a necessity for me.
Motion Blur Studios - Canon XL H1, XL2, nanoFlash, 2xFS-4 HDs, Custom 9TB RAID 10 Array HPT RocketRaid 4320, GeForce GTX 480, Adobe CS5 Production Suite
Jarred Capellman is offline   Reply With Quote
Old August 25th, 2010, 01:20 AM   #2
Did you already spend the $800+ for the plugin? I ask because there is a simple plugin for only $80 Calibrated{Q} XD Decode Overview that lets you play the MOV files within Premiere and AE.
Old August 25th, 2010, 04:50 AM   #3
Thankfully I hadn't, I was only using the demo version. The demo of that plugin worked like a charm, I'll definitely have to purchase it.
