Serious problem with Nano - Page 2 at DVinfo.net
Convergent Design Odyssey
Old July 4th, 2011, 12:14 PM   #16
Re: Serious problem with Nano
Dan.
Info from Clip Browser as I recorded to a MxM Combo simultaneously
End of Z1 017 001 to Z1 018 001 .......17 seconds in between.
Looking at the clips in CB there seam to be two clips missing from the NF.
My next MxM clip starts 10mins after Z1 018 001 stopped, the NF didn't record this.
This clip duration is 12 seconds.
1min 03 sec later another clip is recorded to MxM card lasting 4min 45 sec
The NF didn't record this.
About 7 mins after that another clip lasting 2min 51seconds was recorded to MxM card.
The NF recorded this but missed the first 13 frames.
I recorder to NF for the remainder of the day but didnt check out anything else.
I just went with the MxM cards after that.
Hope this helps.
Anthony McErlean is offline   Reply With Quote
Old July 5th, 2011, 02:28 PM   #17
Sponsor: Convergent Design
Hello Anthony,
Where you by chance rolling the timecode from 23:59:59;59 to 00:00:00:00 when the first error occurred?
Secondly what type of camera and format were you recording? So i can try to replicate this in our lab, (Example Sony EX3, 1080p25 100Mb Long Gop QT)
Did you have Timecode Trigger Delay activated? Which may account for some of the delay or missing seconds, this is found under System>Timecode, but if this was activated every new file created would have the same delay at the start,
Also could you double check that the timecode on the nanoFlash Files match to the natively recorded camera files,
Lastly did you try KLIX to recover your Compact Flash Card, if you are unsuccessful, you can always send the card to us,
Best Regards
Andy Mangrum, Tech Support Convergent Design, Inc
Andy Mangrum is offline   Reply With Quote
Old July 5th, 2011, 04:54 PM   #18
Hello Andy,
I didn't bother with to many settings in the NF, If I get it to do what I want, I just keep it at those settings :)
So I'm not sure what rolling the time code is :)
I have a PMW-320
Trigger TC (Starts/Stops when camera record button is pressed)
MXF files at 35mbps
Delkin 32GB CompactFlash Pro card
Timecode Trigger Delay activated.... I dont think so but will have a look.
timecode on the nanoFlash Files match to the natively recorded camera files.....I will try and find that out for you.
did you try KLIX to recover......No Andy I didn't. I have the missing clips recorded to SDHC card so I'm not to upset about it. Might be more worried if I didn't have them I suppose.
I dont know what caused this to happen, I'm putting it down to this BNC connector.
BNC 75 Ohm Elbow Plug to Jack Adaptor Greenpar Equivalent B37P28J999X99 37528 - Connectors Cables Specialists Ltd
Do you thing the missing clips are still there btw?
Thanks Andy.
Old July 5th, 2011, 05:05 PM   #19
Hello Anthony,
As for the missing clips it is hard to say, you could run KLIX and if the files were recorded it will find them, but it the nanoFlash was powered off while recording, the current file being recorded will be lost,
The Issues you are seeing may be due to the BNC connector, but I will run some test in our lab tomorrow to see if I can replicate the issue,
As for a Bad BNC elbow in theory we should start recording and if we loose the signal we will close the current file and start recording again once we have locked to the SDI,
Do you remember seeing any Error Messages such as "Lost SRC" or anything?
Best Regards
Old July 5th, 2011, 05:24 PM   #20
Hi Andy,
Thanks for taking the time.
Its either the BNC connector or the SDI cable.
Sorry, I didn't see any error message at all.
Thank you again.
Old July 6th, 2011, 07:54 AM   #21
Hi Andy
I'm work on a different project and just noticed 5 or 6 seconds missing from the start of another NF clip.
In this case it doesn't matter if its missing or not because I'm trimming it anyway, but it is missing none the less.
Just so you know, The clip before this one lasts 13.08 seconds.
3mins later I start recording again, this clip lasts 11.13 seconds, about 5 seconds is missing from this clip.
This was all recorder without the BNC connector. (i removed it because of the missing clip from my last project) So I cant blame it this time.
Andy you asked ...Did you have Timecode Trigger Delay activated..
Dont think so ...its sitting at 0
Old July 6th, 2011, 10:37 AM   #22
Hello Anthony,
I would suggest to do a restore defaults, This is found under System>Restore Defaults
and then only change the trigger to time code trigger, This is also found under System>Trigger >Last TC
If this works with no missing time, (at 100Mb Long Gop then I would Try 35Mb)
Best Regards
Old July 6th, 2011, 10:55 AM   #23
OK Andy,
I'll do that but I'm out recording at the weekend again,
I would normaly use MXF files at 35mbps to use less of the CF card.
Thanks.
Old July 6th, 2011, 07:20 PM   #24
by any chance do you have Picture Cache Record set to 'On' in the camera?
Dave Sperling is offline   Reply With Quote
Old July 28th, 2011, 06:56 AM   #25
Hi Dave, sorry, just saw your post.
No, its turned off.
