Please help at DVinfo.net
Convergent Design Odyssey
Old May 10th, 2010, 05:22 PM   #1
Please help
Hi,
The last CF recorded with my nano has mov files that I can't open or read. Theoretically the last four shots are on this card but I see 50 mov files which are locked and have a grey rectangle icon with an "exec" written on the top left corner. Forty something of them are empty files (zero kb) some are 4,5 Mb and four of them has hundreds of Mb. The other two cards I recorded in the first session have readable information on them , they also have between the takes some "one frame" files which I can't explain, but all the footage is there.
Anyone else had a similar experience? What should I do?
I am using 16 GB Lexar Professional 300 CF and I was recording from JVC GY HM 700 at 35 Mb/s.
A second unpleasant thing happened last week when I found that one of the eject button is missing. I don't know how got broken. Is there a solution to replace the missing eject button.
ANy help is very welcome.
Thanks in advance,
Eugen
Eugen Oprina is offline   Reply With Quote
Old May 10th, 2010, 05:29 PM   #2
Dear Eugen,
I am sending you a private email.
I am including Tommy Schell, our support engineer. He will be happy to assist you.
Dan Keaton
Augusta Georgia
Old May 14th, 2010, 09:24 AM   #3
Contributor
Originally Posted by Eugen Oprina View Post
Hi,
Thanks in advance,
Eugen
Eugen - I'm using the same camera and setup and have not experienced any of these issues - I'm using Sandisk 60MB/s cards. I generally record at the 100Mb/s Long GOP without dropouts. I always backup record to the SD cards - do you have backups? The quality of the 35Mb/s inbuilt codec is still pretty good.... in fact identical to what you are doing on the Nano?
Sorry not much help.
John Mitchell is offline   Reply With Quote
Old May 14th, 2010, 11:54 PM   #4
I suspect problems with reading a card would generally either stem from a faulty card or an issue with a computer or a card reader rather than the camera.
Adam Stanislav is offline   Reply With Quote
Old May 15th, 2010, 03:22 AM   #5
John,
I was wrong, I used the nano on the cam B which was a GY HD 251 and for the missed shots I used the backup from the tape which is lower quality. That's why I recorded on 35MBs in order to be compatible with the cam A which was the 700.
Adam,
Is nor the card neither the reader, I used both many times with success.
Thanks for your input,
Eugen
Old May 21st, 2010, 10:13 AM   #6
Eugen,
I experienced something similar with only one file at the very end of a shoot. The file has an .mov file extension, but FCP does not recognize it. Interestingly, it will play back from the nano. I did have backup on the tape from my HDX900, so I was able to transfer the portion from tape (phew).
Have you tried playing the file back from the nano?
Steve
Steve Brown is offline   Reply With Quote
Old May 21st, 2010, 11:00 AM   #7
Closing & Re-Opening the Video Files
Hi Dan:
Based on the picture posted in another thread. It appears as though all of the file data could be on the cf card media. Could it be a problem with the Nano not closing, then re-opening a video file correctly ? Perhaps the header data of the video file is not being written properly ?
Mark Job is offline   Reply With Quote
Old May 21st, 2010, 06:43 PM   #8
Dear Friends,
We will be happy to analyze the card, and see if we can recover the data.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
