Nanoflash with HMC 150/151 / external sound recording with nanoflash
Hi to everybody from the very north of Europe! I want to use the Nanoflash with the Panasonic HMC 150/151. Does anybody have experience with this setup? I need a 4:2:2 50 Mbit/S signal required by the standarts of a local TV station. The HDMI output of the HMC is 4:2:2, so I think this should be fine. I just wonder if the quality would be superior to the AVCHD 24 Mbit/s or if I needed 100 Mbit/s to reach a significant improvement of the picture?
Another question I have concerns the sound capability of the nanoflash: Can I record sound with the nanoflash using the 3.5mm connection when it is connected to the HMC 150 via HDMI? I know in other setups the nanoflash needs to be connected to a cam via SDI if you want to use external sound recording via the 3.5mm connection. I just don't have SDI. Sorry for this beginner qestions, I am just learning. Thank you for helping :) |
Dear Max,
Your television station will probably be happier with 4:2:2 50 Mbps or higher files recorded by the nanoFlash as opposed to 24 Mbps AVCHD. But, in all fairness, this is a question for your television station. For your second question, you can use the 3.5mm external audio input of the nanoFlash when using the HD/SDI video input or the HDMI video input, it makes no difference. It is true, that the nanoFlash will not record just audio, a video signal is also required for the nanoFlash to go into record mode. This video can be from any valid source, HD-SDI, SD-SDI, or HDMI.
Dan Keaton Augusta Georgia |
