#46 |
Wow, I guess the Flash XDR just never quite took off or else you would have been manufacturing the new and and improved model b and c etc. It's probably because everyone is concerned about weight and size. Since you can mow buy 64GB CF cards and soon 128GB cards it sort of eliminates the need for 4 slots. I understand why videographers would want to keep the sound recording in their actual shooting camcorders viewfinder. it's important to be able to monitor both the sound levels and zebra's and other indications at all times. at least it was important to me. I did lots of interviews though.
#47 |
Dear Douglas,
The Flash XDR has a two-channel analog audio output. This allows one to take two-channels of XLR audio into the no-compromise audio circuits of the Flash XDR, process and record it ass 24-Bit / 48K, then send it to the camera inputs so that a redundant recording can be created simultaneously. Thus you can monitor audio levels in your viewfinder. To do this just requires a 5-Pin XLR to two 3-Pin XLR audio cable. While the Flash XDR was the smallest, lightest, lowest power professisonal HD/SD recorder/player when we introduced it, many felt that it was too big for them. Thus, we worked hard to build the second generation nanoFlash which is 40% the size of the Flash XDR, uses less power, and has HDMI inputs and outputs. When the Flash XDR was designed, the maximum size CompactFlash card was 16 GB's. Now, much faster 64 GB cards are available at lower prices and 128 GB cards are being promised soon. With two 128 GB cards, the nanoFlash will be able to record Broadcast Quality (Sony PDW-F800 XDCAM 50 Mbps Long-GOP Quality) for 10.6 hours uninterrupted. Or 14 Hours Sony XDCAM EX quality, or 2 hours using our 280 Mbps maximum quality mode. The nanoFlash also offers analog audio inputs, one channel balanced mic/line, or two channels of unbalanced mic/line, which are processed as 24-Bit / 48K, and a two channel headphone/line output which can be used to feed manay cameras.
Dan Keaton Augusta Georgia |
#48 |
I guess the uncompressed data rate for 1080p @ 60fps 4:2:2 color space is around 1.5Gbs/sec and the uncompressed data rate for 3G-SDI (1080p @ 60fps, color space 4:4:4) is around 3Gbs/sec. Will Convergent Design be coming out with a nanoflash unit capable of handling the 3G-SDI interface or dual-link SDI with a recording time of about 60 minutes at some point?
#49 | |||||
The XDR is a No Compromise Recorder
....Or 25 minutes with 4 x 64 GB CF cards in uncompressed mode in Raid 0 :-) Would think you might get close to 60 minutes with 4 x 128 GB Cf cards striped in Raid 0 (??) |
#50 |
Dear Mark,
Yes, we expected the CompactFlash cards to increase in size and get lower in cost. At one point we were able to get a quality 300x Read Speed, 133x Write Speed, 32 GB card for under $70. This card worked up to 100 Mbps in the Flash XDR and nanoFlash. But, if one steps back for a minute, it is quite a technological feat to have 64 GB or 128 GB CompactFlash cards for a few hundred dollars. I am very happy that you are pleased with the audio quality of the Flash XDR. We did our absolute best to make the audio subsystem great. The audio in the nanoFlash is also very good, but it does not have 65 dB of gain like that Flash XDR does, it only has 44 dB of gain. Of course, this is enough gain for most purposes. I will check on our stock level for the cable you requested. We can certainly custom build one for you if we do not have it in stock.
#51 | |
The current nanoFlash is not designed to accept HD-SDI at 3G, nor is it designed to handle 4:4:4 or 60 fps, or dual-link HD-SDI. I am sorry, but it would be inappropriate for me to speculate on what we might dream up in the future. I can say that if we start work on such a product it would take us many months to bring it to market. The nanoFlash is a very complex product.
#52 | |
Note that just specifying 3G-SDI (or dual link SDI) doesn't tell you what the frame rate, frame size, or color space is, (and dual link or 3G SDI won't handle 4.5Gb/s). Billy |
#53 |
Yes I hear you on that. Although in calculating the approximate bandwidth required in MB/sec it appears that 3Gb/s is around 375MB/s. So are there any external portable (relatively light battery operated) recorders that will support the 3Gb/s rate?
#54 |
that sounds reasonable. I'm sure the NanoFlash is a marvel of engineering. It's probably more than sufficient for my needs I guess testing will tell. 1080p @ 60fps will probably just give you sharper individual frame images (with less motion artifacts). I'm sure it's benefit will be in more action oriented sequences like water & snow skiing or intense fast movement dances and other action oriented sequences.
#55 |
Dear Douglas,
The nanoFlash and Flash XDR are great, in my humble opinon, by not creating motion artifacts. When you use 100 Mbps Long-GOP or above you can be very confident that there will not be too much detail or motion in the scene or camera motion which would result in artifacts. If you have an exteme amount of detail, an extreme motion in a scene, and excessive camera motion, I would recommend 140 Mbps Long-GOP. Of course or higher bit-rate I-Frame Only modes are good also. Background: The Flash XDR which records the same as the nanoFlash was used in a carefully controlled test to check for artifacts. One of our users shot the Houston Marathon using 100 Mbps Long-GOP. 25,000 runners, colorfully dressed, with lots of motion in the image, as runners tend to move up and down while running, were coming towards the camera. This qualifies as lots of detail in the image and lots of motion in the image. The camera was mounted on the back of a moving pickup truck. The camera also had up and down motion as well as occassional side to side motion. In normal playback speeds, no artifacts could be detected. In detailed frame by frame analysis of the long recording, two artifacts were found. Since that test, we added high bit-rates would have eliminated these two artifacts, in my opinion.
#56 | |
With todays solid-state recording media, allowing for some bandwidth headroom, I know of none that support 375 Megabytes per second, on a continuous basis. If one needed to design such a recorder, it would have to be designed to write to multiple media devices in parallel, which is certainly possible. And to answer your specific question, I am not aware of any device under $10,000 that does what you want. Of course, I am be overlooking some device.
#57 | |
#58 |
Dear Douglas,
With the nanoFlash and Flash XDR, when you select a certain bit-rate in our menu, then that is what you get, regardless of the frame rate. Thus 1080i60, 1080i59.94, 1080p30, 1080p29.97, 1080p24, 1080p23.976, and 720p60, 720p59.94, etc. will give you 100 megabits per second if that is what you selected in the menu. Most other recorders do not do this, and the effective bit-rate is reduced for certain frame rates. There is one special case where we convert 720p60 to 720p30 or 720p50 to 720p25. We eliminate the duplicate frames after it has already been encoded, but this is easily compensated for by selecting a higher bit-rate in the menu. The class of camera or camcoder is not an issue if it has HD-SDI or HDMI outputs. The encoding to the desired bit-rate is done in the nanoFlash or Flash XDR, not in the camera. Yes, if you put a nanoFlash on most any camera or camcorder with a HD-SDI or HDMI output you can successfully record almost any level of detail, or motion in the scene, or camera motion. While you stated that you want to find a camcorder with this high level of functionality and high bit-rate built into a camcorder, I do not think you will find one. That is one of the reasons why we built the nanoFlash. Of course if you want to spend a lot of money, you can find high-end cameras that have built-in high-bit rate recorders built in. The Sony SRW-9000 or SRW-9000PL come to mind. For these two specific cameras, while they can record internally, the nanoFlash is a Sony recommended accessory, as the nanoFlash makes an ideal Proxy recorder for these high-end cameras. If you are familar with using a P2 camera with DVCPro HD, you are in for a very pleasant surprise. The nanoFlash's 100 Mbps Long-GOP is superior to DVCPro HD and the workflow is easier.
#59 |
In addition to XDR, I also have a cinedeck extreme. It does support 3Gb/s HD-SDI. I bought it mostly because I wanted the option to do 4:4:4 uncompressed but I never do it. Too much data. I record mostly Cineform 4:4:4 maximum bit rate to SSD. Cinedeck also records uncompressed, ProRes 422 and 4444 as well as Avid DNxHD.
Dan hit the nail on the head though with the "under $10,000" comment. The cinedeck is at least twice the price of the XDR and near three times the price of the nano. These units should not even be compared, they're aimed at completely different markets. There are only a handful of cameras that offer 4:4:4 output at all. They are all high end. If you have a 4:2:2 10 or 8bit camera, you're probably not considering a cinedeck extreme which likely costs more than your camera did. A nano flash is probably a much more sensible choice. |
#60 | |
Although I do recall that some of the camcorders discussed in the various forums on this website (which include SDI & HDMI connectors) don't necessarily pump the 1080x1920 video across to the HDMI or SDI outputs. I also recall reading that some of them don't pump the sound across either. I know we have to be extremely specific now days and you can't be to careful. I was looking at the Canon XF305 as the right camera for my needs but I guess I'll have to read the specs carefully to make sure it or one of the new Sony camera's with SDI support what I need for the Nanoflash out of the SDI/HDMI connector. |
