Beta firmware audio test at DVinfo.net
Convergent Design Odyssey
Old February 22nd, 2010, 09:02 PM   #1
Contributor
With JVC HM700 can confirm that the problem with phased audio appears solved but audio is still two frames late (HD-SDI > Nano).
I may be incorrect but I believe this is a Nano issue as I ran a test to my Avid and audio was in time with the SD card footage recorded on the 700 when recorded out of the SDI port directly to Avid Media Composer via the Nitris box.
I should probably run some other tests when I get time - this was a really quick one.
John
John Mitchell is offline   Reply With Quote
Old February 23rd, 2010, 04:13 AM   #2
Dear John,
Thank you very much for running your tests.
What were the conditions?
Was this in HD or SD, QT/MXF/MPG, bit rate, etc, so we can duplicate your tests?
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
