PCI Firewire 800 & CF Reader at DVinfo.net
Convergent Design Odyssey
Old January 15th, 2010, 12:44 AM   #1
From what I have read, firewire add-in cards can be very troublesome. So, does anyone have experience with SIIG 1394b PCI cards? And what about the SanDisk Firewire 800 CF Reader or Lexar FW 800 CF reader?
Old January 15th, 2010, 02:06 AM   #2
FW CF card readers
Hi Steve, I've bought a SIIG card before - unfortunately the Avid NLE we were using didn't like it so we had to swap it out.
We also use the Lexar FW800 CF readers. They are good - it's nice that they are stackable. I've had 4 readers stacked up which is great for 'fire and forget' loading of lots of cards. One caveat - the card ejection mechanism is quite stiff so you really have to push them home well when inserting cards (it's easy to not quite insert them properly).
Speeds are good - 40MB/s from memory on a single reader and depending on your host system you can stack two and get 80MB/s before you start to saturate the Firewire bus.
I did a bunch of testing on various card reader and HD combos which I'll try to post when I'm in the office.
Hope that helps.
Dave
Dave Chalmers is offline   Reply With Quote
Old January 15th, 2010, 04:10 AM   #3
Hi Steve,
I have been using four Lexar FW800 CF readers they are good and have been trouble free.
Lance Librandi is offline   Reply With Quote
Old January 15th, 2010, 07:49 AM   #4
I'm using the Lexar too and no problems.
However when I eject the card from the Finder, I unplug the FW from the socket before extracting the card.
Rafael
Rafael Amador is offline   Reply With Quote
Old January 17th, 2010, 09:34 AM   #5
I am using a Sandisk FW800 reader...no problems.
Jim Bridges is offline   Reply
