#16 |
Indeed, I failed to make distinction between mp4 and mp4 proxies.
Perhaps due to the fact that - while having many times dreamed of having proxies to the nanoFlash full HD clips - I sort of rejected it as not being viable with the current hardware, and bitrates available.
Sony PXW-FS7 | DaVinci Resolve Studio; Magix Vegas Pro; i7-5960X CPU; 64 GB RAM; 2x GTX 1080 8GB GPU; Decklink 4K Extreme 12G; 4x 3TB WD Black in RAID 0; 1TB M.2 NVMe cache drive |
#17 |
The idea of having proxies written in addition to full-res images is a VERY interesting one. Particularly for NLEs that do not access the media directly, but must copy it over first. I am not sure if systems like CompactFlash would support parallel write operations.
It would certainly be a boon to have DV sized proxy files at say 8-10 Mbps, encoded with the same encoder.
DVX100, PMW-EX1, Canon 550D, FigRig, Dell Octocore, Avid MC4/5, MB Looks, RedCineX, Matrox MX02 mini, GTech RAID, Edirol R-4, Senn. G2 Evo, Countryman, Moles and Lowels. |
#18 |
ProxyMill might work for you
Perrone,
Check out ProxyMill. http://www.imagineproducts.com/index...&products_id=1 It is not quite the same as recording simultaneous .mp4 proxies but it's darn close. You have to back-up the CF cards somehow so doing it through a Mac with ProxyMill might do the trick for you.
Bob FireDancer Productions, Inc. |
#19 |
Thank you Bob,
However, I have two problems with that. 1. I don't use a Mac. 2. I can do the same for free on the PC. :) That looks like a nice option for Mac users though.
#20 |
Thread title changed from "Basic NanoFlash question" to "Question regarding file structure on NanoFlash CF Cards."
Please avoid ambiguous thread titles on DV Info Net. Thanks in advance, |
#21 |
Is it easier to emulate EX or HD...and do we need it?
This is an interesting point raised here - is it easier for a NanoFlash to emulate an EX card or an XDCAM disc, and which gives more benefit?
The Nano is producing 50Mbit files as MXFs with no proxy. The EX produces 35Mbit files as MP4s with no proxy. The XDCAM HD produces 50Mbit files as MXFs with a proxy. In addition the card itself has to be named the right thing. Clearly the Nano isn't about to start producing proxies, so the question is whether, if you create a clone of an XDCAM HD disc BUT without the proxies, is this recognised by NLE apps as a valid disc? (It might be possible to test this by deleting the proxy files on an existing XDCAM disc) Regarding editing off the card - that is effectively what Avid AMA gives you, and I don't know if that needs to see proxies to work or not. CD have already stated that they are working on AMA support for Nano cards in Avid. The FCP import tools from Sony already work with Nano cards, as they are less fussy about file structure etc. I guess maybe it's only the PDZ-1 software on a PC that would benefit from this arrangement, but again it usually works off proxies which wouldn't be there. So, I'm questioning my own assertion that this would be useful. To be selfish I'd settle for Avid AMA support, but clearly there's other scenarios out there. Dave C. |
