NanoFlash Playback Problem at DVinfo.net
Convergent Design Odyssey
Old December 13th, 2009, 01:05 AM   #1
Since I updated to the latest firmware for the nano (1.1.150) I have experienced playback failure. After a 90 min recording sessions in HD & SD mode I would pressed the play button to review the vision and the Nano indicated that it was playing back but I had no output from the SDI. When I reboot the Nano Playback was restored and continued to work as normal.
Lance Librandi is offline   Reply With Quote
Old December 13th, 2009, 03:25 AM   #2
Had exactly the same experience, but *before* updating to the latest firmware...
Old December 13th, 2009, 11:23 AM   #3
Dear Lance,
Please upgrade to 1.1.154!
We found audio sync problems in 1.1.150.
Dan Keaton
Augusta Georgia
Old December 13th, 2009, 03:38 PM   #4
Hello Dan,
I have checked the NanoFlash sorry I posted the incorrect firmware version it is operating on upgrade to 1.1.154 and the problem appears after long duration recordings.
Old December 13th, 2009, 06:37 PM   #5
Dear Lance,
We will test this.
If this happens again, could you just stop playback and start playback again?
I would like to know if that works.
Dan Keaton
Augusta Georgia
Old December 13th, 2009, 09:35 PM   #6
Hi Dan,
I have already done that and no it will not work, you have to power down and reboot. It's a bit of problem when you want to quickly review your take. I am busy with my Christmas work and can not afford the time to test. I will do some testing over the Xmas holidays .
Old December 15th, 2009, 04:47 PM   #7
Convergent Design
Hi Lance-
Is this MPG, MXF or QT file format?
Thanks-
Mike Schell
Convergent Design
Mike Schell is offline   Reply With Quote
Old December 15th, 2009, 07:39 PM   #8
Hello Mike,
It's SD QT file format and buffer on.
Old December 15th, 2009, 10:18 PM   #9
Convergent Design
Hi Lance-
Thanks, we'll jump on this Wednesday and try to duplicate / resolve.
Best-
Mike Schell
Convergent Design
Old December 16th, 2009, 02:03 PM   #10
In my case, it was a 100 Mbps Long-GOP MXF, Mike.
