Help with workflow 25p at DVinfo.net
Convergent Design Odyssey
Old December 5th, 2009, 06:38 PM   #1
Hi,
Would appreciate some advice re my workflow.
Camera Sony EX3 shooting to XDR 180 mbps mxf.
Copy to Nexto 500Gb drives on location.
Will purchase new Mac Book Pro 17" with Esata.
Hope to copy from Nexto drive onto Caldigit 4Gig raid 1 via Firewire 800 in the evenings.
Will format caldigit with fat 32 I presume.
All I need to do is view my mxf files in the Sony XDCam viewer with my client.
There will be no editing on location.
Will edit back in London on AMC.
Regards
Mike.
Mike Leisegang is offline   Reply With Quote
Old December 5th, 2009, 07:20 PM   #2
Dear Mike,
At this moment in time, subject to change anytime, Avid works with our 50 Mbps Long-GOP files, but not at 100 Mbps and above. Avid is working on this, so we expect this to change soon.
Avid does work with all of our I-Frame Only files at any bit-rate.
Thus, at this time, we recommend using I-Frame Only at a high bit-rate, since you will be editing in Avid Media Composer. If you were editing in Final Cut Pro you could use any bit-rate, Long-GOP or I-Frame Only.
To use the highest bit-rates, you need fast CompactFlash cards.
Brand Type Capacity Maximum Bit Rate
SanDisk Extreme III 32/16/8 ...180 Mbps
SanDisk Extreme IV 16 ..........280 Mbps
SanDisk Extreme Pro 64/32 .....280 Mbps
SanDisk Extreme .... 32 ..........280 Mbps
Delkin UDMA .......... 16 ..........180 Mbps
PhotoFast 533x ...... 64/32 .....220 Mbps
Lexar 300x ............ 16/8 .......280 Mbps
Sony XDCam Viewer, Version 2.30 will work well to view any of our MXF files on a PC.
The Sony FCP Plug-In should work to view the files on a Mac. But, please test this if you are using a Mac and do not have FCP installed. (Personally, I have not tested this, but I believe that this does work, I am relying on the information provided by others.)
Here is the direct link to the download page for "PDZ-VX10 Full Resolution Viewer Version 2.30" which everyone seems to call the Sony XDCam Clip Viewer", and Sony also calls "XDCAM Viewer Software (plays all XDCAM MXF files)"
https://servicesplus.us.sony.biz/son...model=PDZ-VX10
Here is the direct link to the dowload page for "PDZ-KP1 XDCAM Transfer Software Version 2.10.0", which they also call "XDCAM Transfer Plug-In for Final Cut Pro (MAC)"
https://servicesplus.us.sony.biz/son...x?model=pdzkp1
For more information, please click on the following:
Sony | Micro Site - XDCAM
Mike, I will send you a private message with my contact information. I will be happy to assist you personally.
Dan Keaton
Augusta Georgia
Old December 5th, 2009, 07:27 PM   #3
Hi Dan,
I forgot to mention I am using I frame.
All I need to do is view the MXF files.
I have the viewer and have a workflow already in Avid on a PC.
The problem is that after this shoot the Mac goes to my wife.
So I need to use the Mac Book Pro for this excersise and boot it in
PC mode.
Is this been done successfuly.
Regards
Mike.
Old December 5th, 2009, 07:31 PM   #4
Thanks Dan.
Mike.
Old December 5th, 2009, 07:47 PM   #5
Dear Mike,
Viewing our MXF files on a PC using the Sony Clip Viewer, version 2.30 is normally very easy and works well.
I assume that a Mac booted up in PC mode will work just as well.
I hope that anyone who has actually done this will offer their experience.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
