Problem after updating firmware to latest release at DVinfo.net
Convergent Design Odyssey
Old December 5th, 2009, 04:25 AM   #1
I have been using an old firmware (1.0.1xx) and recently updated with the intermediate one (1.1.0) and then update to the latest one, .151
However after upgarding that, there is a error message appear
"err checking opt: 00" on the LCD.
recording is fine as well as the triggering so far..
been doing some test and see if i have any sorts of video or audio problem
problem happening at this moment is the timecode will not run on the LCD during recording... (no matter is from LTC or internal generated)
please advise.
cohen
Cohen Leung is offline   Reply With Quote
Old December 5th, 2009, 05:29 AM   #2
It is my understanding that you should have upgraded to 1.0.64 before installing the latest firmware. 1.0.64 was a big mandatory firmware update that all nanoflashes must have.
Paul Inglis is offline   Reply With Quote
Old December 5th, 2009, 11:31 AM   #3
im using XDR instead.
I do follow the instruction regards to older firmware, it must have the intermediate firmware update, i.e. 1.1.0 installed first, which I've did.
and then i've updated the XDR to the latest firmware, and now having the mentioned problem from above on my thread.
please advise. many thanks
cohen
Old December 5th, 2009, 01:04 PM   #4
Firmware this and thats
please advise.
cohen
...Hi Cohen: I think you may have missed one possible intermediary update. (??) I also have an XDR and I remember that we had to do this intermediary update *and* then apply 1.1.64 (I may have this number wrong ??) *only after this could you move forward normally* Mike or Tommy or Dan jump in here if I messed up the update firmware numbers and/or order you must update them as. I am positive that if you had a much earlier firmware on your XDR you *must* perform an intermediary update, (which I understand you have already done ?) then go to 1.1.64x, and then you can go up to 1.1.151. I hope this helps.
Mark Job is offline   Reply With Quote
Old December 5th, 2009, 03:51 PM   #5
Dear Friends,
If updating from 1.0.141 or older version (see System->About), the intermediate update 1.1.0 is required first before updating.
Dear Cohen,
Since you are having problems, may I suggest that you reload firmware 1.1.63,
then re-install 1.1.151.
I will also send you a private message with all of my contact information.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
