#16 |
If iphone can record avchd "like" video and do cuts only NLE right in the phone, what you're saying is totally doable in my mind.
#17 |
I had a good laugh at that. I was going to SAY that.
Why not????? iEDIT
nanoFlash Dealer \ nanoFlash 3D, AJA Kona 3G, DeckLink HD Extreme 3D +, Nuke 3D film/video production since 1972 |
#18 | |
Shoot p29'98 and Conform to p30 in CinemaTools. Just a mouse click, no rendering. BTW: - The Canon only records at p30. - FC can edit p24. Best, Rafael |
#19 | |
Any Quicktime in any Flavor
#20 |
Dear Mark,
Thank you for your informative post. Will Avid handle True 24p while using a Sony XDCam 50 Mbps 4:2:2 @ HL CBR file?
Dan Keaton Augusta Georgia |
#21 |
You're Most Welcome Dan
Hi Dan:
I've upgraded to Avid Media Composer 4.0.3 running on an Avid Certified PC System, so if you require any specific file type testing, then I would be happy to assist you and the folks at CD with beta testor results. I'm also going to take some time and have a close look @ Long GOP 100 Mbps MXF files again. I suspect something. What if I shot Long GOP 100 Mbps, but this time as a simple Quicktime .mov file and imported *that* into AMC ? Dan & Mike & Tommy, I don't know if you've been informed, but that should work for several reasons. If it doesn't then I also suspect a possible work around. I will get back to you and post quantative specific results. Respectfully, |
#22 |
Dear Mark,
We would greatly appreciate you testing, in Avid 4.0.3, the following: Our MXF 100 Mbps 4:2:2 Long-GOP. Our Mov 100 Mbps 4:2:2 Long-GOP. If these work, then you could test higher bit rates. The MXF 100 Mbps 4:2:2 Long-GOP is the most important one for us at this time.
#23 | |
I Forgot To Answer Your First Question
Respectfully, EDIT: I forgot you have some test files at the LOng GOP 100 Mbps rates with different fps on your website, so I'll start with those. Last edited by Mark Job; November 13th, 2009 at 06:48 PM. |
#24 |
Dear Mark,
Here are some test files that Tommy posted earlier. These files are in our latest format, "Sony Optical Disk Format" http://www.dvinfo.net/forum/converge...ml#post1440404
#25 |
Testing, Testing, Testing
Hi Dan:
OK. But these are not Long GOP 100 Mbps MXF files. This is another format. I have just completed a testing of the Long GOP 100 Mbps MXF format, and I will post the the results shortly. I want to check out a possible work around proceedure first. I will test Tommy's files now and post the results shortly. Respectfully |
