download speeds at DVinfo.net
Convergent Design Odyssey
Old October 15th, 2009, 08:20 AM   #1
download speeds
Just finished a shoot. 33 mins of 100mps on a 32GB Kingston card. Plugged into an Mac Pro the download time was detailed as 60 mins. I thought and have download data before working on roughly 2/3 real time to complete. Any one know of a reason why it would take almost 2x real time to dowload?
Chris Atebr is offline   Reply With Quote
Old October 15th, 2009, 08:46 AM   #2
Dear Chris,
This is dependent on your computer setup.
Which Card Reader are you using?
Are your disk drives SATA or eSATA?
Are you transferring to a USB disk drive?
Are you transferring to a Firewire drive? Is is a Firewire 400 drive?
Is the Card Reader a Firewire 400 unit on the same Fireware as a Firewire drive?
If you use a good FireWire 800/400 Card Reader or an ExpressCard 34 Card Reader, and transfer to an internal SATA-II hard drive your transfer can be fast.
If you use a USB Card Reader, then transfer to a USB disk drive, or a Firewire 400 Card Reader, it can be slow.
Dan Keaton
Augusta Georgia
Old October 15th, 2009, 08:48 AM   #3
Chris,
I'm not a Mac user yet, but many (most) of my clients are. Generally, the downloads have been pretty fast for them. I shot over 50 minutes of 50 Mbps HD (Long GOP) for a client last week and it downloaded from my Extreme III SanDisk card in 15 minutes. The following day, using the same setup, a download of much less time said it was going to take an hour. The download did, in fact, start very slowly. After canceling the download and re-trying a couple of times, I suggested he re-start the system. Since I'm a Windows user, I'm familiar with that process :-).
That worked like a charm... go figure.
Steve Brown is offline   Reply With Quote
Old October 15th, 2009, 09:20 AM   #4
Using the CF reader supplied with the Nanoflash - I am getting fairly consistent download times of 1 GB/ minute - using ShotPut Pro and downloading to 3 hard drive systems (all Raid 0) simultaneously. Ony PC here - no MAC's
Barry J. Weckesser is offline   Reply With Quote
Old October 15th, 2009, 12:41 PM   #5
I too get about 1Gb/min with the supplied CF card reader, which I have found to be surprisingly fast for a USB device. I'm using Mac's.
Alister Chapman is offline   Reply
