Firmware updates. at DVinfo.net
Convergent Design Odyssey
Old September 10th, 2008, 08:50 PM   #1
Firmware updates.
Just thought I should ask what form your firmware regime takes. Are they cumulative or does one need to update them sequentially without missing issues in-between?
Jus.
Justin Benn is offline   Reply With Quote
Old September 11th, 2008, 12:42 AM   #2
Dear Justin,
So far, all of them are cumulative.
In other words, you can just install the latest firmwire. You are free to bypass any of the previous firmware updates.
We are working and planning for this to always be the case.
However, for some unforeseen reason, this may change in the future. If so, then a specific base firmware release will be required to be installed before subsequent releases. If this happens, we will be clear in our instructions.
Just as a side note: One of our primary goals, prior to releasing the first "Alpha" units, was to have a workable firmware release system in place.
Dan Keaton
Augusta Georgia
Dan Keaton is offline   Reply
