nanoFlash Details - Page 5 at DVinfo.net
Convergent Design Odyssey
Old July 11th, 2008, 04:24 PM   #61
Gentlemen, let's get real - not all requests and wishes can be fulfilled by the nanoFlash! I'd be more than happy if I could keep it in my breast pocket when shooting hand-held with my EX1 (with the nano either powered through the Coco-ex adaptor, or - in case I need it for a light - from the smaller U30 battery mounted directly on the unit).
With the EX3, it's perfect placement (with or without its own battery) would be the rear cold shoe (put there by Sony with the new HD unit in mind).
With the tripod, the options are many; for instance a cold shoe "doubler" can be used to share the EX1's only shoe between a lamp and the nanoFlash. A cage that goes under the camera is also a viable solution, however certainly not the best one when using a fully-blown rig, including a 35mm adaptor and rails...
Speaking of rails - fixing the nanoFlash to the rails behind the camera with a special bracket could also be a good solution.
Old July 11th, 2008, 05:26 PM   #62
Zacuto has a nice rail mounted wireless plate that will hopefully work -
http://store.zacuto.com/product.php?...14&cat=84&page
E.J. Sadler is offline   Reply With Quote
Old August 1st, 2008, 01:06 PM   #63
Is there any shiping dates for the nanoFlash? I would love to see some stillfootage/movieclips with the nanoFlash and the Sony EX1
Victor Danell is offline   Reply With Quote
Old August 7th, 2008, 11:42 AM   #64
Convergent Design
Hi Victor-
We're in PCB (Printed Circuit Board) layout and cabinet design now. We are hoping to show a unit at IBC in September and go into prodcution shortly thereafter. Since we are reusing 95% of the technology of Flash XDR, we expect the development and debug to require a minimum amount of time (as compared to the Flash XDR).
We plan to post footage from XDR and the EX1 later this month. The video footage would be identical from either XDR or nanoFlash as we exactly the same CODEC (the Sony module) in both boxes.
I'll try to keep you posted on our progress from time to time.
Mike Schell
Convergent Design
Mike Schell is offline   Reply With Quote
Old August 7th, 2008, 11:54 AM   #65
Mike will you have your own stand or are you sharing stand space at IBC. Where can we find you?
Old August 7th, 2008, 12:57 PM   #66
Convergent Design
Hi Alister-
I should be either at the Symbiosis stand (they are our EU distributor) or over at the Canon booth. I plan to be at the show all 5 days.
Mike Schell
Convergent Design
Old August 7th, 2008, 02:22 PM   #67
Originally Posted by Mike Schell View Post
We have a Coco battery adapter in route to us directly from Bebob. We are very excited to start testing this adapter and confirm functionality with our Flash XDR / nanoFlash. We should also be able to report the run times using the big BP-U60 battery.
Stay tuned for more info.
Mike,
How are your tests with the Bebob's Coco-ex? As a yet another alternative solution, you might have a look at this:
http://www.dvinfo.net/conf/showthread.php?t=127614
Old August 7th, 2008, 02:41 PM   #68
Convergent Design
Mike,
Hi Piotr-
Yes, that looks quite interesting, I'll look into it more. We do have our Coco adapter and it seems to work quite nice. Now we just need a nanoFlash box...
Mike Schell
Convergent Design
