Convergent Designs Flash XDR - Page 14 at DVinfo.net
Convergent Design Odyssey
Old April 20th, 2008, 02:55 PM   #196
How about Grass Valley/Canopus Edius?
Old April 20th, 2008, 08:14 PM   #197
Convergent Design
This is all very nice, but:
- still no word on mounting option for Sony EX1
- still not even a shortest sample of 50 Mbps 4:2:2 which not only would help us assess quality (which I believe will be great), but also let us try out our current NLE's (using Vegas personally, I wouldn't like the idea of being forced to invest in Liquid, or a hardware card for HD-SDI capture, at all !!)
Mike?
Hi Piotr-
Sorry, but we have been a little busy with NAB. However, our engineers stayed home and worked on XDR while I relaxed at the show!
We do have images at 50 Mbps and 100 Mbps 4:2:2. You can see a definite improvement over 25 Mbps HDV, but it's hard to see the difference between 50 and 100 Mbps. I am sure that we'll see a difference in high-detail and/or high-motion footage. I will try to get images posted this week for download, but I'll need to offload to a file streaming site, as these could overload the bandwidth of our server.
I will also meet with our mechanical engineer to discuss mounting options to the various cameras. I'll post some concepts ASAP.
Mike Schell
Convergent Design
Mike Schell is offline   Reply With Quote
Old April 20th, 2008, 08:24 PM   #198
Convergent Design
Flash XDR at NAB
Dear DV Info Members-
We want to thank everyone who stopped by our booth last week at NAB. We appreciate your comments and suggestions. We were, quite frankly, swamped. We had Flash XDR units at our booth as well as the Canon, Iconix and Polecam. All locations reported high levels of traffic. Thank you!
We are also excited to report that Flash XDR won two awards: Videography Magazine Viddy award and Broadcast Engineering Pick Hit. Again, we thank everyone's comments and recommendations throughout these last 9-12 months as these helped us define Flash XDR into an award winning product!
We will send an e-mail blast update later this week with photos and more details.
Sincerely-
Mike Schell and the Convergent Design Team
Old April 20th, 2008, 08:25 PM   #199
Convergent Design
Hi Tim-
Can you e-mail to me a good technical contact? I would like to send them test MXF files.
Mike Schell
Convergent Design
Old April 20th, 2008, 08:45 PM   #200
Here's a couple of NAB photos to start off with...
Convergent Designs Flash XDR-flashxdr1.jpg   Convergent Designs Flash XDR-flashxdr2.jpg
Old April 20th, 2008, 09:02 PM   #201
Images: 5
That's a good bit larger than I had imagined. Is that the actual size or were those things just rough mockups?
-Ethan Cooper
Ethan Cooper is offline   Reply With Quote
Old April 20th, 2008, 11:04 PM   #202
Hello Mike,
I don't know who would handle this type of request.
I might suggest the forum moderators at http://ediusforum.grassvalley.com/forum/index.php
Or a call to tech support at (801) 222-5204 might lead you in the right direction.
Old April 21st, 2008, 02:34 AM   #203
Exactly my first thought, too. Actually, with the unit being this huge, it's not a question how you attach it to the EX1 camera - rather how you attach the camera to this monster :)
I don't know why, instead of reading the specs carefully, I imagined it being the size of the Sony DR60 drive!
Old April 21st, 2008, 07:10 AM   #204
Images: 5
I've seen under camera cage mounts that hold firestores so I'm guessing that wouldn't be a bad option for this thing with smaller non-shoulder mounted cameras. Maybe you could also stick it on the back of one of those 3rd party shoulder mounts for the oversized handycam types too. If the image quality gains of this thing are as advertised, someone will figure out a good way to mount it to almost anything.
I can now understand why it wouldn't be a great match for say an HV20 or that sized camera.
-Ethan Cooper
Old April 21st, 2008, 07:38 AM   #205
Considering that it's a $5,000 SDI recorder, it was never a great match for a $900 non-SDI HV20.
Old April 21st, 2008, 07:48 AM   #206
Convergent-Design will be designing a custom bracket for the XL H1 and XL H1s to hold the Flash XDR.
The photo of the Canon XL H1s shows the Flash XDR resting on the standard bracket that comes with the XL H1s. This bracket is not custom designed for the Flash XDR. The custom bracket will probably hold the Flash XDR lower.
Dan Keaton
Augusta Georgia
Old April 21st, 2008, 07:53 AM   #207
Yeah, on the spur of the moment I had asked Dan to hold the Flash XDR up to the XL H1 accessory bracket, and he said "what, like this?" and I snapped the photo. I didn't put a whole lot of thought into it.
Old April 21st, 2008, 09:05 AM   #208
Hi,
Sorry to add to this negitive point, it looks big to me as well.
Would need to use off camera somehow, sound crazy but strapped to my arm or something.
Suggestions would be great.
Mike.
Mike Leisegang is offline   Reply With Quote
Old April 21st, 2008, 09:25 AM   #209
The Flash XDR is relatively big, but not as big as it looks in the first photo of Chris's.
I do not know what lens Chris was using, but we have a "Wide Angle Lens" effect in that photo, in that items closer to the lens look bigger, and items farther away look smaller.
Just take a look at my hand, it looks much bigger than the Canon lens.
Of course the Flash XDR is bigger than what was originally planned, but it is not as big as it looks in the first photo.
Convergent-Design announced the nanoFlash at NAB. This unit will be much smaller and will have different capabilities.
For example, the nanoFlash will have two Compact Flash card slots instead of four which will allow the unit to be smaller.
In addition, the nanoFlash will probably not have the four additional power supplies which are required to support world class analog audio inputs.
The nanoFlash will still support audio embedded in the HD-SDI bit stream, as does the larger Flash XDR, but not XLR mic inputs with phantom power.
Mike Schell will post the actual weight and size of the Flash XDR as soon as possible.
Dan Keaton
Augusta Georgia
Old April 21st, 2008, 09:38 AM   #210
NanoFlash - sounds so interesting, even though I already have paid the deposit for the XDR! For my needs, the 2x32GB CF cards and no additional XLR inputs would be just enough - if accompanied by a lower size and price tag...
Mike, please update us on the nanoFlash; when will it be available?
