What is the use of the CineformRAW software? at DVinfo.net
CineForm Software Showcase
Old July 5th, 2007, 08:40 PM   #1
Im used to work in prospect for editing and procesing of the RAW files, so i only used the CineformRAW software in the camera computer.
I moved to another city for a couple of weeks for work and i had to make use of one of the two CineformRAW licenses that ships with the camera?
What I dont know is what is the use of that software, is it only for playback of RAW files?
I`ve noticed that the files arent recognized in Post apps, and i cant use to export from other files to cineform neither.
What can i do with it?
Sergio Sanchez is offline   Reply With Quote
Old July 5th, 2007, 09:36 PM   #2
CTO, CineForm Inc.
You asked for the CineForm RAW download, I just assumed you wanted the latest camera compression software. For editing CineForm RAW you need the standard NEO 2K or Prospect 2K packages.
Old July 5th, 2007, 11:36 PM   #3
Im not complaining at all... now i realize that my question is rough in english...Have patience with me David sometimes i ask the questions like in spanish...sorry.
I remember that in the first release I used in october last year I could load RAW files in AE and Premiere...and do some testing.
The files opened using the AE raw importer in that time...
I didnt used the software since then...just to encode in the camera of course...
But i`ve noticed that now Premiere and AE does not recognize the software... I just can playback the shots on my laptop.
I deactivated the RAW license in one computer because I needed it to install a Shake and linux on it so I thought, now that im away office that I could keep testing footage with the RAW license.
So CineformRAW is just for SI and Wafian encoding?
Is there any way to transform my file to another format that Premiere or AE can read, maybe an image sequence?
Old July 6th, 2007, 08:31 AM   #4
CTO, CineForm Inc.
You missed my short answer.
CineForm RAW is an ingest format, however every one of our editing tools can decode it. The best tools are NEO 2K and Prospect 2K as they have the 4:4:4 encoding that allows you to render out to a compressed format without loosing any detail. You can also use NEO Player to get AE and Premiere decoding support for CineForm RAW.
Old July 7th, 2007, 05:12 PM   #5
Ok David thanks, NEO player is really helpful for refining the DPX tests i`m doing.
Thank you again.
Old August 6th, 2007, 04:28 PM   #6
The HV-20 has a single chip (allbeit small) and Bayer RGB Primary Color Filter. Would it benfit from CineForm RAW?
Thanks.
Old August 6th, 2007, 04:52 PM   #7
CTO, CineForm Inc.
Thanks.
Only if you hack the HV20 to get at the RAW unprocessed data from the camera head. CineForm RAW is designed to record the sensor data before it has been converted to YUV or RGB pixel formats.
Old August 12th, 2007, 03:17 AM   #8
Are you aware of this being successfully done?
Old August 12th, 2007, 07:32 AM   #9
Do you have tech documentation for HV20 from Canon's service centers?
Serge Victorovich is offline   Reply With Quote
Old August 12th, 2007, 09:57 AM   #10
CTO, CineForm Inc.
Like Serge suggests, maybe you can be the first to try.
Old August 12th, 2007, 05:32 PM   #11
Maybe, LOL!
Peter Moretti is offline   Reply
