Latest CS3 and CineForm Aspect/Prospect. at DVinfo.net
CineForm Software Showcase
Old May 17th, 2007, 01:17 PM   #1
CTO, CineForm Inc.
I know several of you have be using the Adobe public beta of Premiere Pro CS3. This is great as Adobe needs all the feedback they can get, particularly if an Adobe bug impacts using your CineForm tools, which Adobe is not testing for. In the latest CS3 release, the plug-ins registry path changes are incompatible with many existing installers, this means your Aspect HD installer, which was working fine, will no longer function on CS3. I have complained, but Adobe has their reasons. As I want you to continue using the CS3 beta and reporting bugs, here is the patch to address the Adobe changes.
The attached download has registry keys for changing where the plugins are installed. These registry keys assume a default Premiere install to "C:\Program Files\Adobe\...", if you installed elsewhere you can simply text edit these *.reg files.
Once CS3 is installed, before installing Aspect HD or Prospect HD/2K, double click on the FixPluginsPath30.reg file. Now the CineForm install will work correctly. To restore the new Premiere plug-ins folder of other components you can optional then use RestorePluginsPathCS3.reg.
Others have noticed removing CS3 breaks installing tools back into older versions of Premiere -- this is true. To fix an older install after removing CS3, run the file that matches your Premiere Pro verison.
FixPluginsPath15.reg or FixPluginsPath20.reg.
I hope this is helpful.
Old June 1st, 2007, 08:41 PM   #2
Okay, trying to load CS3 cineform. So, first tried normally, and it did not work no CF in CS3. I remembered reading about a bug, so here was the solution. I uninstalled CF, I ran fixplugins, and reran the 129 Prospect installer. I run CS3, and I see a CF folder when I start CS3, but nothing in it.
So, any ideas how I messed it up?
Dave
Dave Campbell is offline   Reply With Quote
Old June 1st, 2007, 08:54 PM   #3
CTO, CineForm Inc.
Try build 3.0.1.130, just posted.
Old June 1st, 2007, 09:15 PM   #4
update points to 129 still
Salah Baker is offline   Reply With Quote
Old June 1st, 2007, 09:20 PM   #5
Refresh your browser and try again. I just went to Cineform.com and got the 130 build through the update button.
Pete Bauer
Old June 1st, 2007, 09:23 PM   #6
sheeze, David,
BM checks updates/firmware as we start the program, I game for it in CineForm
Old June 1st, 2007, 09:30 PM   #7
still Prospect2KDLv301b129-070518.zip via email
Old June 1st, 2007, 09:54 PM   #8
CTO, CineForm Inc.
I don't know why the dual link version is still 129, both were updated.
Old June 2nd, 2007, 06:50 AM   #9
Does one still need to use the registery trick for build 130?
Will give it a shot
Okay, just read the log, and says the CS3 install issues are fixed
Dave
Old June 2nd, 2007, 08:11 AM   #10
Okay, build 130 fixed the CS3 install issue.
Dave
