NEO HDV + Canon XH-A1, won't split? at DVinfo.net
CineForm Software Showcase
Old May 13th, 2007, 03:53 PM   #1
Hi, simple post ..
Capturing from XH-A1, variety of 25F and 50i footage.
Neo HDV (downloaded today) HDLink isn't splitting scenes! I've tried it straight to cineform, to cineform+m2t, and to m2t alone ... no splitting :(
Is anyone else doing this successfully?
Kris Bird is offline   Reply With Quote
Old May 13th, 2007, 04:32 PM   #2
File a ticket and ask for Tim Bucklin
Salah Baker is offline   Reply With Quote
Old May 13th, 2007, 04:46 PM   #3
Already filed a ticket, so I appended a note for it to be assigned to that person...
Have you had similar problems ..?
I have a promo that needs edited/graded to be finished a little over a week from now, our editor is holding off starting until we know whether we can go the cineform route .. (as opposed to hdv, which sucks for 150+ cuts in 3mins)... Hopefully I'll get some resolution asap :)
Otherwise, cineform looks like a dream to work with.
Kris
Old May 13th, 2007, 04:51 PM   #4
Tim works on HDLink .
He had a reslolution for me in less than 24
Old May 13th, 2007, 05:16 PM   #5
"Have you had similar problems ..?"
it may be my issue that broke yours...lol
Old May 13th, 2007, 05:20 PM   #6
It happens :) Have an older version handy ? ;)
Old May 13th, 2007, 05:52 PM   #7
Kris, while you're waiting for Tim's response, I have a couple things to suggest:
1) Try a utility called "HDVSplit" to split your HDV files. You can then use HDLink to convert the split files to CineForm Intermediate. More on HDVSplit in this thread: http://www.dvinfo.net/conf/showthrea...light=hdvsplit.
2) You can download the previous version of Connect HD on the CineForm downloads page by clicking on the "Update" button: http://www.cineform.com/products/Dow.../Downloads.htm. Put in a random number for the serial number and it'll return a link to you. We didn't do any update to the splitting algorithm when we moved up to NEO, but some people seem to report different behavior for some reason.
David Taylor is offline   Reply With Quote
Old May 13th, 2007, 06:38 PM   #8
Cheers David!
HDVSplit splits them no problem, will do that and convert to cineform for the time being!
Tried uninstalling my version of NEO and installing older Connect HD versions-- seemed to behave in the same way, no splits!
Old May 13th, 2007, 07:03 PM   #9
All right - at least you have a workaround in the mean time....
Old May 16th, 2007, 09:55 AM   #10
Hi, just a follow-up .... I've been capturing another project with HDVSplit (to M2T) and then converting the M2Ts into Cineform Avis with HDLink ... HDLink is regularly freezing up (the window stops responding), and I have to kill the process. I know that HDVSplit reported 2 dropped frames in the 4 hours of video--- In what circumstances would HDLink it freeze up?
So at the moment I'm in a position where I can't have faith in my folder of cineform footage as I've had to keep "resuming" the batch compression, and I know for a fact that one ~20minute take has been truncated to ~3mins long ...
If only HDLink would capture and scene split direct from the A1 =\ Is *anyone* doing this successfully? If so, what version of HDLink/cineform?
