Cineform and Squeeze at DVinfo.net
CineForm Software Showcase
Old May 11th, 2007, 01:56 PM   #1
There were known problems getting Soreson Squeeze 4.3 to open Cineform avi files. But since then I've read several threads with posters saying the problem had been solved with an update to Squeeze.
Today I tried getting Squeeze 4.5.5.001 (PC version) to accept a Cineform avi encoded with Aspect 4.3.176 ... and still had no luck!
Can anyone confirm that this combination is working for them? Is anyone still having problems?
Old May 11th, 2007, 02:49 PM   #2
CTO, CineForm Inc.
I spent many nights trying to determine what Sequeeze's problem is. It does seem to have a broken AVI importer, as other AVI types are not working well either with no scrubbing preview, although CineForm AVIs seem to have a worse time. Export to an MOV wrapped CineForm file works fine, so it is not CineForm compression, it is Sequeeze's handling of our AVIs. So either don't use a CineForm export format, or use Aspect HD v5 and export to a CineForm QuickTime which works fine in Sequeeze.
Old May 11th, 2007, 06:37 PM   #3
Graham, you can also use the file conversion utility in AHD v5 (or NEO for that matter) which literally re-wraps CineForm AVI files to MOV files (or vice-versa) without touching the underlying compression. Because it's literally replacing the wrapper it's almost as fast as a file copy.
David Taylor is offline   Reply With Quote
Old May 11th, 2007, 07:02 PM   #4
Thanks guys - good to know its not just a quirk of my system.
Old May 11th, 2007, 09:39 PM   #5
Images: 57
Works perfectly with mov wrapper. I convert a 444 P2k clip and rendered out an mpeg2 DVD quality without issue, and I'm using SS 4.3 -no need to upgrade to 4.5 :)
Pete Ferling http://ferling.net It's never a mistake if you learn something new from it.
Peter Ferling is offline   Reply With Quote
Old May 11th, 2007, 09:46 PM   #6
Yeah, I have to say though - I don't plan to start rendering out to movs. Aspect 4 is fine for all my other purposes.
I'll use the huffyuv codec and/or stick with Procoder.
