Aspect V5 - Page 2 at DVinfo.net
CineForm Software Showcase
Old May 3rd, 2007, 06:55 PM   #16
CTO, CineForm Inc.
Yes, thank you John. There have already been a bunch Aspect HD users to join you in Prospect HD in the last couple of days. We hope for many more.
Old May 4th, 2007, 08:54 AM   #17
Hi David,
Is there an update log available between the V4 and V5?
I don't see any on your website, unless I overlooked a link?
Marc Colemont is offline   Reply With Quote
Old May 4th, 2007, 09:31 AM   #18
CTO, CineForm Inc.
With the site updates that may have beeen missed.
Keying elements :
1) New codec for even higher quality (using the Prospect core.)
2) HDSDI/HMDI capture support with HDLink using a range of AJA or Blackmagic cards.
3) Quicktime support for import and exports.
... plus more..
Old May 4th, 2007, 10:37 AM   #19
Thanks David for the fast respons as always.
Old May 4th, 2007, 01:10 PM   #20
So looking at those v4 to v5 updates, I won't see any quality improvements for my current project, where all the footage is already captured?
Doug Turner
http://therunsmovie.com
Douglas Turner is offline   Reply With Quote
Old May 4th, 2007, 01:29 PM   #21
CTO, CineForm Inc.
Douglas,
The codec upgrades are primarily encoder changes, so any new encodings will benefit. This includes CineForm exports from Premiere/AE of your existing projects.
Old May 4th, 2007, 05:09 PM   #22
OK, thanks. We have a test screening at the start of June, so I'll delay trying v5 until then...
Doug Turner
Old May 10th, 2007, 02:24 AM   #23
Hi David,
I installed the AspectHD V5 trial, and imported some MOV trailer clips I downloaded from the Quicktime Pro website to have good MOV footage to convert as a test. (shrek3 trailer 720P)
But when I start the conversion the debugging displays an error on the MOV-file were the codec is not supported.
The Move-file plays fine on my laptop, and Premiere Pro 2.0 can read and convert it to Cineform. Do I need to install something extra from Quicktime? I have the Pro 7 installed.
Old May 10th, 2007, 09:20 AM   #24
CTO, CineForm Inc.
Marc,
Some QuickTime files will not convert with HDLink as the decoder is not available in DirectShow, even if it is available to QuickTime, many codecs are available to both. If you can play the MOV in MediaPlayer when it should convert. We do plan to add full QuickTime based conversion support to HDLink to address this, although it is a low priority as there are work-arounds like you have found with Premiere.
Old May 16th, 2007, 08:32 AM   #25
Thanks for the info David.
Is there a list of Quicktime codecs you currently support? Because I have a few clients in the Non-video business who needs to convert many quicktime media into AVI for our media servers. Adobe premiere and Procoder have too many settings for them. I would like to recommend to buy Neo HDV instead when it works with all kinds of Quicktime codecs.
Old May 16th, 2007, 09:19 AM   #26
CTO, CineForm Inc.
Once we complete the QT interface to HDLink we will support the decoding and conversion too CineForm for anything QuickTime can handle. Today the QuickTime support is about using CineForm compression with QuickTime, which widens our compatibility greatly.
