Blackmagic 8-bit MJPEG vs CineForm HD - Page 4 at DVinfo.net
CineForm Software Showcase
Old March 15th, 2010, 09:06 PM   #46
CTO, CineForm Inc.
Unless you are used it already, the license server is typical set for two activation per serial. You might just want to try it.
Old March 16th, 2010, 07:13 AM   #47
negative
Hi David. I definitely have 1 activation (for NeoHD). I got this message when I tried to activate on my capture box..I wont post the serial and other personal details at the bottom but I can PM you with those details if you like..
Dear ANMOL MISHRA,
This serial number has already been activated. If you wish to transfer your CineForm software to another PC, you will need to deactivate your existing installation first and provide to us the deactivation code that is generated.
To deactivate your previous installation of CineForm software:
1) To deactivate your installation, your CineForm software must be installed. If you have uninstalled it, you must reinstall it in order to deactivate it.
2) Click the Start Button
3) Click on 'All Programs'
4) Click on 'CineForm'
5) Click on the folder that corresponds to your product
6) Click 'Activate'
7) Be prepared to write down your deactivation code. Click 'Deactivate'.
8) You will be prompted to confirm that you wish to deactivate. When you confirm deactivation WRITE DOWN the deactivation code. It is also recommended to take a screenshot of the deactivation code as well for your own records.
9) Visit Deactivate.aspx and fill out the form with the appropriate information.
Best Regards,
CineForm Support
SUBJECT: Activate Submitted
CONTENT:text/plain; charset=us-ascii
mishra.tv Productions
A Sydney-based group for dance movement-based video and film productions.
Anmol Mishra is offline   Reply With Quote
Old March 16th, 2010, 09:23 AM   #48
CTO, CineForm Inc.
Not an issue, then support will help you.
