#31 |
Xena LH and Aspect Question
Since Premiere 2.0 offers built in support for the card in both SD and HD what will Cineform do with the Aspect plugin to take advantage of that, if anything? Will it still be limited to Prospect or will you turn it on for Aspect but in 8 bit? Sure would be a shame to get all the benefits of the card using .m2t but not get it using Aspect. Given that the new Canon H1 is 8bit HD-SDI wouldn't that make a nice fit?....not to mention it will beat the heck out of using a video card for monitoring.
#32 |
CTO, CineForm Inc.
Currently Premiere Pro only has support for the Xena HS, not the new LH series cards, but your point is still an interesting one that are considering (certainly for timeline monitoring.) For capture and HD-SDI mastering we have the Prospect HD line.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
#33 | |
#34 |
Will this card work for output to HD with Cineform?
Found this on the web and wanted to figure out the best economical solution to going to an external HD monitor working with Cineform....
http://www.tigerdirect.com/applicati...027&CatId=1562 I know there's two cards in the $200-$300 range recommended by Cineform but I was curious if there were less expensive cards that would work as well. Can't help it, I'm thrifty :) Chris Watson Watson Videography www.dynamovideo.com |
#35 |
Hard Drives for archiving.
What have been the experiences of using External Hard Drives for storage? Types, Mfgr., etc. Who uses a raid configuration, and what is the configuration?
How about SATA,,, Is it necessary for archive storage? Is a single drive OK? Firewire or USB 2.0? Any other methods of storage besids Tape or Ext. Hard Drives being used? Any new storage/backup possibilities in the near future? Thanks, Gary |
#36 |
Hawaiian Shirt Mogul
i've been buying 400 gig ATA drives (seagates on sale 114 - 159) .. install then in either 2 or 4 bay external 1394a/b/USB2 cases ... both 2/4 bay allow raid 0 but i just run them as single drives ... also have several 250gig externals 1394/usb ... tried tape a few years ago -tooooo slooooooo and to hard/time consuming to look for just certain files.
#37 |
I archive to 7200rpm ATA drives (not SATA) in USB 2.0 enclosures. I find that they are plenty fast enough - so much so I can play 720p/60 files at very high quality setting with no dropped frames.
I can even capture to them too at the same rates if I want to, not that I would recommend it. Rather than go the SATA/RAID route you would most likely be better off simply archiving twice to different drives. In terms of manufacturers, Maxtor are really hitting a bad patch at the moment so I'd avoid them like the plague. |
#38 | |
Best, Christopher |
#39 |
Video card/output question
Hi,
I currently have a eVGA 7800GT connected to my Dell 24" LCD and a Dell 19" LCD. I recently purchased a Toshiba 20" widescreen that will take HDV 1080i/720p via Component or VGA, and I'm wanting to output from Premiere Pro to that TV. I know I need another video card, but I was wondering if that was possible to use my computer in that configuration? Thanks, Jim |
#40 |
Is my computer good enough
I have a sony laptop wich is a couple years old. pentium 2.4, 512 ram, ati mobility radeon 7500c video card.
My question is, will I be able to use cineform connect hd with vegas on my laptop to edit HVX200 footage? Or will it not work. I really don't want to buy another computer if I don't have to. |
#41 |
CTO, CineForm Inc.
You could be in luck. Generally people use the HXV200 in 720p24 or 25 (with over/under-cranking for effects as needed.) 720p24/25 is particularly easy that many under-spec'd PCs will work fine. I suggest down the CineForm trial, and test the performance on your PC for yourself.
#42 |
Possible ways to postpone new laptop purchase
Ryan,
Looking at your specs, your memory could probably do with an upgrade to 1Gig. This will give any app. plenty of room to play in. Also, laptops have slow hard disks: 4200rpm is the norm. I have purchased an external eSATA unit and put 2 x 250Gbyte 7200rpm SATA disks in RAID 0 array into it (500Gigs). Currently I am accessing this via USB2 interface but eventually when motherboards and laptops support it will be able to use that interface. All my Media now goes on this portable unit so I have decoupled my media from my PC with a very fast interface. Another thing to try are Gearshift from VASST (uses smaller rendered temporay files in place of the larger .avis) Nick. |
#43 |
Xena HS PCI? or PCI-X?
I can't seem to nail down the specifics on this card, some list it as a PCI card, some a PCI-x.
Does anyone know if this card will do HD on a regular PCI motherboard? I'm starting to believe I'll have to upgrade to a system with PCIe, but if I can put that off for a bit that would be great. |
#44 |
John, I just went to the AJA site and noticed they are not good about identifying the bus requirements for their cards. But the Xena-HS requires a 64-bit PCI-X slot. PCI-X is generally available on workstation-class PCs, but not all, so you'll have to check your machine. If you don't have a 64-bit PCI-X slot then you can use the Xena-LHe which works in a 16-bit (I think) PCIe slot. That card is more expensive than the -HS because it includes component HD I/O in addition to HD-SDI.
If you also purchase Prospect HD we can supply either card, and we have bundle pricing for both the -HS and -LH(e) family. |
#45 |
yeah, looks like I'm going to have to upgrade my system to go either route. No PCIe or PCI-x
Funny? It was fast enough a year ago :-) Moore's law sucks. |
