Missing Audio at DVinfo.net
CineForm Software Showcase
Old February 13th, 2007, 08:11 AM   #1
Missing Audio
I have recorded some 720/50p footage shot with JVC GY-HD201 using Cineform Aspect HD. When I play the clips they look great, I have audio and everything is fine.
When I put them on a timeline i Premiere Pro 2, the audio is missing. What am I doing wrong?
Alexander Kristiansen is offline   Reply With Quote
Old February 13th, 2007, 08:31 AM   #2
Check to see if you have the latest version. I believe that David updated the latest version (released last Friday?) with a new version released yesterday that fixes a glitch with audio in Premiere. This might be your problem.
Good Luck!
Marty Hudzik is offline   Reply With Quote
Old February 13th, 2007, 09:21 AM   #3
CTO, CineForm Inc.
Yes, that is it. All our products went through a minor update yesterday afternoon. For Aspect HD you need 4.3.1 build 76, the current download link was upgraded so just download it again. You will need to delete Premiere's audio conform files other PPro will not look for the audio.
Old February 13th, 2007, 10:42 AM   #4
The latest update sorted out the problem of missing audio, but now it appears as if the audio is slightly out of sync. Does anybody else get the same feeling?
Lauri Kettunen is offline   Reply With Quote
Old February 13th, 2007, 10:46 AM   #5
CTO, CineForm Inc.
Nothing has changed with the audio. The bug with the missing audio, was just a typo in code, we weren't changing anything in this area.
Old February 15th, 2007, 06:40 AM   #6
I had some clips in PPro 2.0 that the audio disappeared from. I deleted the preview and media cache folders, PPro reprossed them, and the audio returned -- just a thought.
Wayne
Wayne Johnson is offline   Reply With Quote
Old February 15th, 2007, 07:21 AM   #7
Could not find build 76, only 75! No offence, but isn't there a way to fix a typo without uninstalling and reinstalling the entire program again? Am I going to need new keys?
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old February 15th, 2007, 08:12 AM   #8
Mike
When I re-DL 'dthe "new" build, it was still identified as 75 on the Cineform site, but upon unzipping, the exe file said 76. Solved my problem
Dearl Golden is offline   Reply With Quote
Old February 15th, 2007, 08:13 AM   #9
Mike
When I re-DL'd the "new" build, it was still identified as 75 on the Cineform site, but upon unzipping, the exe file said 76. Solved my problem
Old February 15th, 2007, 08:27 AM   #10
Did you end up having to uninstall and reinstall the whole program?
Thanks--Mike
Old February 15th, 2007, 09:11 AM   #11
CTO, CineForm Inc.
A component re-install of CineForm components only takes a minute (if that.) If we told you the one small thing to change it would take longer.
Old February 15th, 2007, 09:29 AM   #12
Thanks David,
I am used to having to go through new key codes and such with every change, emails, support tickets and all. This one was easy.
Thanks----Mike
