CineForm and Sony XDCAM HD - Page 3 at DVinfo.net
CineForm Software Showcase
Old November 8th, 2006, 04:24 PM   #31
XDCam HD plug in
I really don't care if it is a Aspect Module or Prospect addtion. I just wish that Cineform would support the FAM Workflow for the XDCAM HD 350. I know that I can still capture the video through the AJA card and all that good stuff. I also know someday it will happen that the FAM workflow is going to be the standard, but I hope and wish that I can stay with the Adobe workflow and not have to switch Apple. Which I believe a few people on this forum had to do because no one on the PC side sees this camera as a real contender in Video Production. I guess Mainconceipt but so far I hear it really is not worth installing. That is why I wish Cineform would implement the FAM workflow for the XDCAM 350. They have a solid rep and you know that their products will work that is why I would like to see them do this for all who use the XDCAM 330/350. I guess I could look at the AXIO. Axio is actually a grand more then Prospect. They do support FAM but only for import.
Matthew Pugerude is offline   Reply With Quote
Old February 12th, 2007, 09:52 AM   #32
Help with HDLink Export to XDCAM
HELP!
I'm trying to use HDLink to Export a M2T file via firewire into an XDCAM HD Deck with MPRG TS Card option and HDLink is not cooperating.
The Deck and the card work as I can take my Z1U and transfer stuff in and out of the PDW-F70. It's only HDLink that insists on rolling the F70 on record then goes into a tizzy when it can't talk to it.
I don't want HDLink to record the F70.... I just want it to stream bits out. How can I disable transport control, or does anyone have a better way to do this?
thanks!
Stacy Rothwell is offline   Reply With Quote
Old March 15th, 2007, 03:04 AM   #33
XDCAM HD support?
Any news on MXF XDCAM HD support in Cineform?
Bart Walczak is offline   Reply With Quote
Old March 19th, 2007, 09:28 AM   #34
XDCAM HD support?
I'd like to second this request...if there's any update please post. Thanks.
Immanuel Martin is offline   Reply With Quote
Old March 19th, 2007, 11:14 AM   #35
I'm in, just do it.
Jim
Jim Montgomery is offline   Reply With Quote
Old July 30th, 2007, 01:52 PM   #36
Prospect 3.xx and XDCAM HD
I just installed the latest Prospect update that supports XDCAM HD. What is the ingest procedure? I can't find anything on the site when I search for XDCAM or XDCAM HD.
Thanks.
Tip
Tip McPartland is offline   Reply With Quote
Old July 30th, 2007, 02:39 PM   #37
CTO, CineForm Inc.
Mount you XDCAM media/camera and convert the MXF files, either directly by specifying the output path, or copy the MXF data to your local drives first.
Old July 31st, 2007, 10:43 AM   #38
Doesn´t work
Hi David,
Tried Aspect and Prospect in three diferent computers. Can´t put to work with files already in a folder, in the computer.
Any clues?
Didn´t tried straight from the camera.
Gérson
Gérson Becker - Lumiere Produções - Brasil
www.lumiere.com.br/cinemadigital
Gerson Becker is offline   Reply With Quote
Old July 31st, 2007, 11:11 AM   #39
CTO, CineForm Inc.
Send the some sample files to support, or provide a download link here.
Old August 1st, 2007, 01:28 PM   #40
files
Hi David,
Can you send me your private email? So I can send you a ftp address to download three files that I just uploaded, so you can test.
And I can send you the messages that I received.
Gerson
gerson@lumiere.com.br
Old August 1st, 2007, 04:36 PM   #41
CTO, CineForm Inc.
I was able to convert your clips. However I did find an issue with the clips with only 2 channel audio, all our samples have 4 channels. So Banrisul0004.MXF converted fine, yet Ipanema0046.MXF & CapsulaZH-090.MXF required a small patch HDLink that will get into the current build. I'll send you the patch.
Old August 3rd, 2007, 08:27 AM   #42
Patch
Hi David,
Do you know when you gonna send the patch?
I can´t convert any of the three files.
Thanks.
Gérson
Old August 3rd, 2007, 09:00 AM   #43
CTO, CineForm Inc.
No need, all the new builds are up and they work fine with XDCAM-HD MXF clips, give it a try.
Old August 3rd, 2007, 02:08 PM   #44
Hi David,
Just downloaded and tried Aspect and Prospect.
Neither worked. HDLink that comes with Aspect shutdown when I try to convert from MXF to AVI.
HDLink that comes with Prospect returns this message: Format not avaiable (P2 viewer missing).
But I´m trying to convert a XDCam HD file, not P2.
The version is 3.0.5 Build 135. There is no capture card installed in the computer.
I tried two different computers, with a up to date SP 2 installation.
Since I´m in Brazil, the XP comes in Portuguese. Don´t know if this can be a problem.
I read in other posts that some guys installed and are working with the files.
Do you think this can be a instalation problem?
Old August 3rd, 2007, 03:23 PM   #45
CTO, CineForm Inc.
It seems the HDlink can find the MXF libraries on your PCs.
Attached is .reg file, download, unzip and edit it: modify this line to much the path on your PC.
"DataDir"="C:\\Program Files\\Common Files\\CineForm\\Data"
Then double click on the .reg file to update this entry. I'm guessing that the "C:\\Program Files\\Common Files\\CineForm\\Data" path doesn't exist on a Portuguese XP install.
If this works, will will have a official fix in the next build.
File Type: zip MXF.zip (301 Bytes, 142 views)
