ONly imports a fraction of total material at DVinfo.net
CineForm Software Showcase
Old July 5th, 2006, 02:03 AM   #1
Images: 1
After importing an entire tape of footage in AspectHD demo and waiting 2 and a half hours to encode it, Premiere only recognizes the first seven and a half minutes of footage. It's as if the other 53 minutes were never recorded. What's going on? Is this a demo limitation?
BenWinter.com
Ben Winter is offline   Reply With Quote
Old July 5th, 2006, 03:05 AM   #2
No, I don't think so, and it shouldn't take 2.5 hours to capture a tape. How did you do the capture? Did you use HDLink or Premiere? If you did not use HDLink, then try capturing the tape again using HDLink.
Best,
Christopher
Christopher Glaeser is offline   Reply With Quote
Old July 5th, 2006, 10:22 AM   #3
Images: 1
I should add that the .avi file shows a duration of 59 minutes. The entire tape was correctly imported, but Premiere shows the file as only 7 minutes long.
BenWinter.com
Old July 6th, 2006, 02:32 AM   #4
Workaround
Hi Ben,
I know it's not a solution but I always break up my imports into 5-10 minute manageable chunks. I just don't trust working with files over a certain size.
Nick.
Nick Outram is offline   Reply With Quote
Old July 6th, 2006, 08:16 AM   #5
Same here. Try using HDLink with scene detection and see if that fixes the problem.
Best,
Christopher
Old July 6th, 2006, 01:19 PM   #6
Sponsor: CineForm
What is the framerate of the file within Premiere? Also, does that 7 minutes play normally? or is it the entire 59 minutes sped up? or something else?
Jake Segraves is offline   Reply
