Aspect HD to DV letterbox: settings? at DVinfo.net
CineForm Software Showcase
Old June 29th, 2006, 08:58 AM   #1
Have Aspect HD 1440x1080i30 video (16x9 of course).
Need to quality downconvert to DV 720x480 4x3 letterboxed.
Created a standard 4x3 NTSC project in PPro 1.5.1, imported AHD video, placed it in the timeline, applied 34% scale in Motion section.
Looks OK on screen - letterboxed and correct proportions, as needed.
Trying to export in Microsoft DV (is that the one I should use?) all sorts of distortions creep in.
Proportions are now all wrong; video has pillar boxes on top of letterboxes; etc.
What are the correct export settings for my purpose - quality downconvert to DV 720x480 4x3 letterboxed?
Alex Raskin is offline   Reply With Quote
Old June 29th, 2006, 09:38 AM   #2
Suggestion: I use PPro 2.0 now, but if you are down converting a 16:9 HD to DV, why not open a project as HDV, import the file you want to down convert, then use 16:9 DV as an output/rendered file from the original project ? Why go through the motion menu process. Are you saying that gives you the distorted file? If so, output it to a standard 4:3 DV file. Try those, and I think one will work.
Chris J. Barcellos
Old June 29th, 2006, 09:41 AM   #3
Chris, I need 4x3 DV letterboxed out of the 16x9 AspectHD.
And I can't make it work, need to know exact export settings from PPro.
Old June 29th, 2006, 09:54 AM   #4
CTO, CineForm Inc.
Don't mess with new 4x3 projects and motion. From your original HD project simply export movie to 4x3 DV 720x480 with a 0.9 pixel ratio. The letterboxing will be added automatically.
Old June 29th, 2006, 11:12 AM   #5
Thanks David, your suggestion worked.
However the resulting video displays very visible "running" line edge artifacts on horizontal/diagonal objects.
Is that a problem with PPro downconversion? Output DV settings are at 100% quality though.
Old June 29th, 2006, 11:34 AM   #6
CTO, CineForm Inc.
You could also do a CineForm export to the same format to see if it is DV issue or a scaler issue. If is it simply aliasing you can place a blur filter (radius 2 will be ok) to limit aliasing.
Old June 29th, 2006, 01:09 PM   #7
Fantastic! With Fast Blur at 2.0 amount, no more running edges on DV copy!
Once again, thanks David!
