Export to tape: PPro crashes at DVinfo.net
CineForm Software Showcase
Old June 26th, 2006, 08:23 PM   #1
Using an older Aspect HD 3.?? (3.5 I think) with PPro 1.5.1
Sony Z1U is attached via firewire and is recognized and controlled by PPRo just fine - except for the actual recording.
Everything is fine except for Export to Tape.
It goes all the way through rendering the audio and video files, positions the tape (to the default 10 sec. point), and then pops the dialog asking: "Do you want to export previously rendered m2t files?"
Whether I say Yes or No, PPro simply hangs after that.
Z1U displays "recording paused" icon for awhile, then goes to stop.
Alex Raskin is offline   Reply With Quote
Old June 26th, 2006, 11:39 PM   #2
CTO, CineForm Inc.
Sorry, I don't know the older Aspect is doing that. Work around : use Export Movie -> CineForm M2T, the quality is better and you can easily use HDLink to export the file.
Old June 27th, 2006, 07:06 AM   #3
David, many thanks for your fast reply - your suggested workflow worked beautifully!
