Rendering time to Cineform intermediate? at DVinfo.net
CineForm Software Showcase
Old April 26th, 2006, 07:40 PM   #1
I have a fairly straightforward project, with a mask track and two source tracks, all in HDV format.
I am rendering to Cineform HDV intermediate - however, it seems to be taking over one hour to render 6 minutes of video.
Is this normal? What are typical HDV -> Cineform intermediate render times?
Gian Pablo Villamil is offline   Reply With Quote
Old April 26th, 2006, 08:06 PM   #2
It is very difficult to answer that question because some effects take a long time to render and some do not. Did you use the Cineform effects where available? That makes it faster I believe.
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline   Reply With Quote
Old April 27th, 2006, 08:00 AM   #3
Surely the editing system's CPU, memory and hard disk configuration would also have an impact on the time an export will take?
Company Website: Digital Foundry Ltd
Video Games HD Blog: Digital Foundry@Eurogamer
Richard Leadbetter is offline   Reply With Quote
Old April 27th, 2006, 08:38 AM   #4
Sure. That makes a huge difference as well.
Steven Gotz
Old April 27th, 2006, 09:21 AM   #5
CTO, CineForm Inc.
Typically we are one of the faster formats to export to, so the sounds like a old system or some heavy effects on that timeline.
Old April 27th, 2006, 09:22 AM   #6
Well, I'm using AMD Athlon 64 X2 (4400), on a system with 2GB RAM and 2 SATA II drives internally. Generally, rendering to MPEG2 from HDV on this system is usually about 4x playtime of the final video.
What should a straight-across transcode of HDV to Cineform take (roughly)?
Old April 27th, 2006, 09:26 AM   #7
CTO, CineForm Inc.
Using HDLink to do the conversion on a PC like yours, near 1:1 real-time. We have a very fast encoder (threaded for as many cores available.)
Old April 27th, 2006, 09:42 AM   #8
I have a much slower system. Only 3.06GHz with 1.5G RAM.
I created a new project and put a few Cineform AVIs on the sequence in Premiere Pro 2.0 with the latest Aspect HD (not the beta) totalling 2 minutes. (00;02;00;03 drop frame)
I didn't add it to the project, and I didn't embed the project. I did export the audio. There were no transitions or any effects applied at all, so no red line to eliminate with a render.
I used the Cineform HD Export and unchecked Recompress. I did not Optimize Stills.
3600 frames rendered out to a new movie in 6:18 - or a little over 3X realtime. Not too shabby. Although I have to wonder what is happening other than just stitching the clips together? Why not a lot closer to realtime?
Steven Gotz
Old April 27th, 2006, 05:30 PM   #9
Yep, my results are comparable. A much simpler 50 second clip, with only a crop operation applied, took 3 minutes to render.
Old May 15th, 2006, 04:17 AM   #10
long rendering times
This maybe a shot in the dark, but...When you render, did you accidentally uncheck the render loop region only box? I've done that before and which resulted in long render times. I have a 3ghz/1gb RAM/dedicated video drive machine and it takes 5-6x realtime for render. The only effect I have used that takes so long is Magic Bullet.
Michael May is offline   Reply
