Thread Tools
Search this Thread
Sound not in Synch when exporting with CineformHD
When File/exporting/Movie/CineformHD any very simple ( even with no rendering, just trimming ) sequences( from 3 to 7 minutes),
I get now SYTEMATICALLY some sound A-synchronism.The sound is EARLY , And it seems that the gap increases from very slight at the first minute to quite significant ( more than three seconds at the end of a 7 minutes clip). When played from the Time Line everything seems ok. I'm using PPro 1.51 and AspectHD v3.4. Such glicth did not exist with previous versions. Any idea out there ?? Thanks for your input.. |
Are you using build 45 of Aspect 3.4? If you have 3.3.038 see if it still does it with that, build 45 should have taken care of that, I would upgrade to 4.0, it is the llatest version.
Mike |
Thanks for your answer. I am using build 43.
I moved back to 3.3. It does correct my bug. CURIOUS that i am the only one to suffer from that !!... I am not too confident in moving to 4.0 while it is in its early days...Would you know where to find a Build 45 as it seems that Cineform only offers to upgrade to 4.0 even if it is in its infancy... Last edited by Pierre Barberis; February 5th, 2006 at 11:41 AM. |
I experienced the same problem, I use 4.0, you will be fine using it.
Mike |
#5 |
If there are those using Aspect HD with a Build number prior to b45, and who prefer to NOT upgrade to Aspect HD v4, you can still upgrade to AHD v3.4 b45. If you click the "Upgrade" button on the website you'll see the page is primarily for Aspect HD 4, but the first line allows you to upgrade to AHD v3.4 (b45) instead.
