Problems with Field Dominance in FCP7 project at DVinfo.net
CineForm Software Showcase
Old September 26th, 2012, 07:14 AM   #1
I am using FCP7 in FCS3. I set all my project settings to Field Dominance -> None
When use a roundtrip and send to Motion or STP, the stap or motn file replaces the original clip in my timeline.
I have a format problem with Cineform, essentially FCP interprets all my Cineform clips as Upper Field instead of None Field Dominance.
Is there a way I can access the underlying clips and re-render after changing the Format -> Field Dominance to None ?
I noticed that this causes some stair stepping artifacts otherwise.
mishra.tv Productions
A Sydney-based group for dance movement-based video and film productions.
Anmol Mishra is offline   Reply
