3D controls error in Studio Premium. at DVinfo.net
CineForm Software Showcase
Old August 11th, 2012, 08:15 AM   #1
I have been using the horizontal convergence control in Studio Premium. I have found that if I close Studio and then reopen Studio I found that the horizontal convergence settings had been reset as a vertical convergence setting.If I close and reopen again the resing switch back again. As far as I can see I think that Studio is switching the settings when the database is read.
Trevor Harris is offline   Reply With Quote
Old August 12th, 2012, 01:31 AM   #2
CTO, CineForm Inc.
Re: 3D controls error in Studio Premium.
Which platform? I'm not seeing that on Windows.
Old August 12th, 2012, 01:55 AM   #3
I am using windows 7 profesional 64bit. Firstlight is ok. Just tried it again so it is reproducable. I will try latter today on anoth video.
Regards Trevor
Old August 12th, 2012, 02:04 AM   #4
CTO, CineForm Inc.
I'm also using Windows 7 profesional 64bit, although I testing with the next release which didn't do that. Contact support with details on how to reproduce this. support@cineform.com
Old August 12th, 2012, 05:39 AM   #5
Ok done some more testing. If you don't use keyframes its ok.
This is what I did
Move to point on clip and set keyframe with default controls.
Move on 1 frame and set full 3d horizontal with auto zoom on.
Move on a few seconds and set another keyframe with the same full horizontal.
Move on 1 frame and set to default.
Close studio and reopen it and go to second keyframe and the 3d vertical will be displayed.
Old August 12th, 2012, 09:34 AM   #6
CTO, CineForm Inc.
Confirmed, well that is messed up. Working on a fix now.
Old August 12th, 2012, 09:58 AM   #7
CTO, CineForm Inc.
The fix was easy, we will try to get into into tomorrow's beta build.
