Proxy some issue.
Hi,
under seven 64bit, GO Pro. 1.1.2.100 today i found some issue about proxy. i build a 3d from old sequence, two mov. i muxed both in a mov, i tried to do some proxy, with hdlink proxy option, if i setup 960x... work the proxy if i setup proxy1920x... hdlink wirte a small .mov black. if i do same operation, but with avi container work fine. and again... stereo eye alignment... if i do stereoalignment with proxy, the eye shift is not correct referenced... i setup parallax on 960x file, i see on 1920 out of parallax... is proxy only for color corrections? |
