Export to what format at DVinfo.net
CineForm Software Showcase
Old April 12th, 2012, 09:26 AM   #1
Hi there,
This is a very basic question but the export process is driving me slightly nuts.
I wish to export a 3D clip and test it on YouTube. However, the end result is to be viewed using LG Cinema 3D glasses (not the red/cyan type). I remember doing a similar test some time back but I have forgotten which export I need to use;
Line Interleaved
Onion Skin
Difference
or FreeView
I imagine that all exports using the Anaglyph Red/Cyan will require the Red/Cyan glasses which are, in this case, not required for the end result.
In fact, if you've seen the GoPro 3D promo on YouTube, then you'll know what my goal is.
Thanks for any help you can give ...
Stuart
Stuart McAlister is offline   Reply With Quote
Old April 12th, 2012, 09:54 AM   #2
CTO, CineForm Inc.
Re: Export to what format
If you use the CineForm Studio app is has a YouTube 3D export mode. Otherwise you want side-by-side 3D for youtube. If you want to do local file for direct use on the TV, export under-over (better for passive TV displays for more resolution.)
Old April 12th, 2012, 10:07 AM   #3
Thanks David.
A few months away from the software and I switch to default mode! Thanks again for putting me right.
Stuart
