#46 |
Re: New GoPro CineForm product line is out today.
Taky, hasnt it always been yellow though?
#47 |
I don't recall the yellow line before when using NeoHD
LA Color Pros Blog RODE Authorized Reseller . Comer LED Camera Lights . TakyBox HTML5 Menu Generator |
#48 |
Well i use Neoscene with Adobe CS5.5 and it has always been yellow. As long as its not RED, you're in good shape!
#49 |
NeoScene doesn't provide timeline preset to be used in Premiere Pro. It's the Desktop mode. But for NeoHD, it has several Cineform timeline presets for better editing performance.
#50 |
hmmm......if your talking about Cineform presets, Neoscene has always had them in my Premiere Pro.
#51 |
Is there a way for the new studio premium to import entire folders instead of just individual files one by one??? I can't seem to figure it out if you can. If not, that's a MAJOR issue for me. Also anybody having playback issues??? After I do the conversion the sound plays back fine but the video is very choppy. I can bring in some old conversions and they play just fine. So far I'm not that jazzed.
#52 |
CTO, CineForm Inc.
Jerry, talk to support. Doesn't make sense that new files play different that old.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
#53 |
David a ticket has been submitted. Is there a way to batch convert folders or do I have to bring in the files one by one? If it's the latter that's a deal killer for me.
#54 |
CTO, CineForm Inc.
Range select or multi-select work fine. So you can bring in hundreds of clips in one step.
#55 |
#56 |
CTO, CineForm Inc.
Explain? Do you have a camera that uses folders for clips?
#57 |
I have the same issue with the new studio. I shot weddings with DSLR. At the end of the day, I will have 8 to 15 SD cards that I save them in folders so I know which clips is from which camera. in HD Link, I can pick "Select Folder...". If I didn't check the "Use Capture Location for converted files", I can retain the folder structure.
In Studio, I am having problem using it the first time. The interface is slow. While converting, if I click on any other thumbnail under the Conversion List, the conversion stopped.
#58 |
For the Studio tool, it's not even clean the "Advanced" button settings. Does it apply to the current clip only? Does it applied to all the clips in the conversion list? or does it apply to the clips selected? I imported a bunch of 24p clips to Studio. In the Advance button dialog box. Some showing the clips are 29.97fps.
I'm just lost in this new interface. I think it might be okay to split the batch conversion function outside Studio so there will be faster operation. I'm glad HD Link is still included. I think I'm going to stick with HD Link for batch conversion for now.
#59 |
CTO, CineForm Inc.
Why not simply drag the folder you want from Window Explorer into the import bin? That works.
I'll add the feature request for convert in place. As for speed, it should be a fast as HDLink. Please contact support with bug reports.
#60 | |
CTO, CineForm Inc.
