Neo First Light - Page 2 at DVinfo.net
CineForm Software Showcase
Old January 3rd, 2012, 08:39 PM   #16
CTO, CineForm Inc.
Re: Neo First Light
v7.6.1 will be in the next public release, only minor changes in the codec.
For some reason the Premiere API we use, or the way we use it, is slow. We are 80+% of the time waiting for Premiere to send frames, seems worse on newer computers (less of an issue in the past.) I still using CineForm AVI for my projects as it is the best quality, but they are generally under an hour long. The old AVI export seem to be more effecient from Premeire with the VfW codec is slower (95% of the CPU is Premiere not the encoder, so it does matter.) Quality issue will be very minor, I doubt you could tell the difference, particularly if you use FirstLight for color correction.
Old January 3rd, 2012, 10:20 PM   #17
Re: Neo First Light
Okay, I did the trick and the export is done within an hour. Oh boy, wasted an entire day. Thanks for helping out David.
LA Color Pros Blog
Taky Cheung is offline   Reply
