Replace audio Cineform track in FCP - unnecessary encode at DVinfo.net
CineForm Software Showcase
Old May 24th, 2011, 12:05 AM   #1
Hi! I am using pluraleyes to replace an audio track from the camera with one recorded off camera. I have the camera file aligned with the off-camera audio.
Now I proceed to delete the audio from the camera file.
At this time when I export, (keeping the same settings) FCP should just re-encode the audio. This should not be more than a few minutes.
I get 7 minutes on a quad core for a 2 min Cineform file. This leads me to believe that FCP is re-encoding the original file.
Is there a way to prevent this ? To force a "Smart Encode" where only the audio is encoded ?
mishra.tv Productions
A Sydney-based group for dance movement-based video and film productions.
Anmol Mishra is offline   Reply With Quote
Old May 24th, 2011, 10:50 AM   #2
Re: Replace audio Cineform track in FCP - unnecessary encode
When you export (Export QuickTime...) make sure that the option to "Recompress All Frames" is not checked.
Craig Davidson is offline   Reply With Quote
Old May 24th, 2011, 11:12 PM   #3
Hi Craig. That option is not checked. I have exported qt references before and they work well with ProRes.
Could I suggest that you try this on a Mac ? Its easy to see what would or would not work.
A qt reference would be faster than realtime - so a 1 min. clip would take less than a min. If you are taking 20 min to export a qt reference, clearly FCP is recompressing the CF file.
Old May 26th, 2011, 10:33 PM   #4
I tried that on my laptop (Mac) and exported a timeline almost 3 minutes long in 5 seconds.
Old May 27th, 2011, 04:45 AM   #5
Interesting, is there anything special in your Sequence or A/V settings ?
I only have the recommended settings in Sequence, CF as the render codec, everything else the same.
Does it matter if there are lots of cuts in the timeline for a CF qt reference ?
Old May 27th, 2011, 02:54 PM   #6
It should not matter if there are a number of clips in the sequence. I tried a longer 'movie' with 4 clips and it still only took about 5 seconds. I added a title over some clips, and that did render.
The sequence matches the source clip. Start with an empty project, add a clip and let FCP match the sequence settings to the clip.
Old May 28th, 2011, 01:40 AM   #7
I did a few experiments today. Turns out that when I created my projects, FCP asked me to match the sequence settings. I said No.
Now I have an hour of edited footage that refuses to conform to the sequence settings.
Hence I cannot make a qt reference, and everything is re-rendered. If I start a new project nd bring in the files fresh from the hdd, it renders fine.
I tried using the manual conform - that does not work either.
Any suggestions ?
