Can't decompress CineForm in Compressor! at DVinfo.net
CineForm Software Showcase
Old April 7th, 2011, 01:58 PM   #1
For some reason, we can't seem to decompress or transcode video material from CineForm 2D to h.264 or any other CODEC in Compressor.
One of two errors shows up in the batch monitor
1) Quicktime Error -50
2) CODEC not found
The errors only appear after the footage has been chewed through. In other words, we see the progress bar chewing through the footage, and it usually takes the expected 10-20 minutes to make it through the footage. Once it appears to have completed, only then does it report an error, and all of the progress files disappear.
We literally have Terabytes of footage in some CineForm 2D format. We've downloaded the free NeoScene Player, and can play the files in quicktime no problem. In addition, the movies show up just fine in the preview window.
Anyone have any ideas or suggestions?
Tim Johnston is offline   Reply With Quote
Old April 7th, 2011, 04:39 PM   #2
Re: Can't decompress CineForm in Compressor!
Open the CineForm system preference pane and make sure all the pixel formats are enabled. Compressor/QuickTime will return this error if a pixel format it expects is not supported. Playing in QuickTime only uses the 2vuy (8-bit YUV) pixel format, but compressor will usually request one of the deeper formats.
Craig Davidson is offline   Reply With Quote
Old May 10th, 2011, 12:08 PM   #3
Thanks, Craig, I'll have to try that when we get a chance...
We actually discovered that it if we got rid of the IN/OUT points in compressor, it went through smoothly. Not sure what it would be about setting IN and OUT points that would make CineForm angry, but that's what worked for us. I'll have to try using IN / OUT points with "All Pixel Formats" enabled to see if it works any better. Will report back...
Old June 23rd, 2011, 04:02 PM   #4
Yeah, as it turns out, that didn't work for us either. I ensured that all the 'pixel formats' boxes were checked. For some reason, we just can't choose in/out points in compressor. We got the 'Failed' result and 'QuickTime Error -50' again
