Visual Keyframing on a MAC... & PC ? at DVinfo.net
CineForm Software Showcase
Old February 23rd, 2011, 07:36 AM   #1
Yes! Great work guys. Love the way you designed this. with the positioning of the keyframes above and below the timeline marker to indicate what type of keyframe placed, brilliant.
3 questions:
1. When will this be coming to the WINDOWS version?
2. Can you add a toggle button to the WAVE panel to jump between keyframes? There are a lot of unused buttons! (eg. the F1 buttons) or a toggle button to choose which type of keyframes to switch between.
3. Can you add a button / option to create 'hold' keyframes / not animated keyframes? They could be indicated in the timeline with a different color of keyframe marker. Typical colorists are used to being able to create notches - and you're one step away from this! Currently I have to create 2 keyframes for every scene change which can become cumbersome and time consuming (especially if one keyframe accidentally gets forgotten and all the changes animate during a take).
Great work!
Justin Lovell
cinematographer//8mm.16mm>HD.transfers . www.framediscreet.com
Justin Lovell is offline   Reply
