Release cadidate for v5.3.1 at DVinfo.net
CineForm Software Showcase
Old February 20th, 2011, 12:42 PM   #1
CTO, CineForm Inc.
This is the release version probably be officially released on Tuesday. As there is a holiday Monday, nothing is likely to change between now and then. Let us now if they are any big things broken, but I expect you will find this a very solid release.
Neo3D http://cineform.com/downloads/Neo3Dv531b303-110221.zip
Neo4K http://cineform.com/downloads/Neo4Kv531b303-110221.zip
NeoHD http://cineform.com/downloads/NeoHDv531b303-110221.zip
NeoScene http://cineform.com/downloads/NeoSce...303-110221.zip
Build 5.3.1.303, released 22-February-2011
Added: support 4444 (alpha channel) sources to use FirstLight and Active Metadata corrections.
Added: support for r408/v408 decodes with alpha channel.
Added: support for 3D corrections for interlaced sources.
Added: support for framing corrections for interlaced sources.
Added: Alpha channel exports from Premiere Pro CS5.
Added: some .3dl support for the LookInstaller.
Enhanced: 100+ generations quality for 16-bit pixel formats.
Enhanced: 2D source can now be used in 3D productions.
Enhanced: the 601 to 709 math use for Canon DSLR video conversion.
Fixed: QuickTime 444 export pop-up window has been restored.
Fixed: QT encodes from RedcineX where missing metadata needed for FirstLight keyframing.
Fixed: DPX2CF filename length issue. Very long filenames wouldn't load.
Fixed: ParseCFHD tool to work with 3D uncompressed CineForm sources.
Fixed: a startup condition made adding keyframes to a new clip in FirstLight weird.
Fixed: Cut and paste of Keystone and DepthTilt in Neo3D's FirstLight.
Fixed: a Premiere CS5 crash.
Old February 20th, 2011, 04:59 PM   #2
Fixed: a Premiere CS5 crash. Which crash was fixed?
Leo
Leo Baker is offline   Reply With Quote
Old February 20th, 2011, 07:00 PM   #3
CTO, CineForm Inc.
We found and fixed few issues with the Premiere plugins over the last few weeks, but I don't have details.
Old February 21st, 2011, 01:39 AM   #4
Re: Release cadidate for v5.3.1
Hi All,
I can only recommend that new build, the enhancements are well worth it. Boundaries have been pushed once more.
Congratulations to David & the Cineform team for this important build,
Axel
Axel Mertes is offline   Reply With Quote
Old February 21st, 2011, 06:25 PM   #5
I am still gettingthe crash in Adobe Premeire pro using a Cineform preset using the latest RC. Reported it to Jake a few months ago.
I nest clips on my timeline, then I add a transition then Adobe Premiere pro cs5 crashes.
Faulting application name: Adobe Premiere Pro.exe, version: 5.0.3.0, time stamp: 0x4ce382d1
Faulting module name: CFRTPlayback.prm, version: 1.0.0.1, time stamp: 0x4d5f5c53
Exception code: 0xc0000417
Fault offset: 0x000000000002ba74
Faulting process id: 0x9b0
Faulting application start time: 0x01cbd2253669ad31
Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro CS5\Adobe Premiere Pro.exe
Faulting module path: C:\Program Files\Adobe\Adobe Premiere Pro CS5\Plug-ins\Common\CineForm\CFRTPlayback.prm
Report Id: ddf0c22e-3e18-11e0-b6b3-0022643237f0
Leo
Old February 21st, 2011, 06:41 PM   #6
CTO, CineForm Inc.
We haven't yet looked into the nesting issue, I have also reproduced this. For now either don't nesting or use the desktop preset.
Old February 22nd, 2011, 03:29 AM   #7
Please...PLEASE can we fix the nesting issue soon! I posted the bug many months ago and it adversely affects my workflow. The work-around causes major slow downs that would not be necessary if this one issue was fixed. I know I'm only one person, but this bug has to be the most detrimental that I have experienced in Cineform and my editor is really fed up with the issue. (I can understand why) I understand that features are the name of the game when it comes to software, but quality features are what keep customers happy.
Ryan Gard is offline   Reply With Quote
Old February 22nd, 2011, 01:25 PM   #8
CTO, CineForm Inc.
The nesting bug just went away (not a single code change on our end.)
Test now and fast if you want this in the pending release.
http://miscdata.com/temp/CFRTPlayback.zip
Unzip and replace in C:\Program Files\Adobe\Adobe Premiere Pro CS5\Plug-ins\Common\CineForm
Old February 22nd, 2011, 02:14 PM   #9
Okay, I will test tonight to see if it works.
Old February 22nd, 2011, 02:58 PM   #10
Hello David,
I just tested nesting and adding transitions, all works perfect thank you! What was the fix?
Leo
Old February 22nd, 2011, 03:02 PM   #11
CTO, CineForm Inc.
Adobe SDK, its sample code had the bug. Updated the SDK.
Old February 22nd, 2011, 03:11 PM   #12
That is great news! Thanks for the fix it's much appreciated.
Old February 22nd, 2011, 09:17 PM   #13
Links are broken.
Old February 22nd, 2011, 09:48 PM   #14
CTO, CineForm Inc.
beta is over.
The release is available through normal channels, although we have detected an issue so hold off 24 hour if you can.
Old February 22nd, 2011, 10:53 PM   #15
CTO, CineForm Inc.
New patched releases for everything uploading now, ready in about 30 minutes. Request your download link through Cineform
