sound sounds awfull at DVinfo.net
CineForm Software Showcase
Old February 9th, 2011, 05:57 PM   #1
sound sounds awfull
the audio in a exported avi sounds awfull in CS5, crackling, ticking.
I had to revert to 5.2.7.290. Audio is back to normal.
Old February 10th, 2011, 11:50 AM   #2
I have also had the sound problems you mention and after reading your comments have gone back to 290 and presto the crackling has disappeared. I hope Jake or David read this, because the sound problems persist in the latest beta.
Thanks Ann!
Carlos Bustamante is offline   Reply With Quote
Old February 22nd, 2011, 06:21 AM   #3
Re: sound sounds awfull
just installed latest version. Release candidate ... same sound problem... like it's chocking or smthin ...
Can anyone provide me with an older version that works ? 290 or smthin like that
Sorin Pricop is offline   Reply With Quote
Old February 22nd, 2011, 11:09 AM   #4
CTO, CineForm Inc.
Anyone documented this with support, as we have no bug filed in this area?
Old February 22nd, 2011, 12:36 PM   #5
I got bad audio when transcoding with HDLink as well. I have seen (heard) this before when upgrading from version X to version Y. I once had a fresh install of Windows on another computer and when i installed version Y it worked as a charm. It seems that the uninstaller dont remove everything when one uninstall the old version. I have seen this many times and then i needed to manually remove all left over traces from the old version.
No, i am afraid that i have not logged any bugs for this.
/Roger
Roger Averdahl is offline   Reply With Quote
Old February 22nd, 2011, 01:40 PM   #6
5.3... doesn't do it for me either.
Went back to 5.2.6.289
Noticed this only on exported avi.
Gildo Houtekamer is offline   Reply With Quote
Old February 22nd, 2011, 03:08 PM   #7
I exported an edit from Premeire pro cs5 into a Cineform AV file, I get perfect sound. I just converted an existing Cineform video file with sound AVI under Windows using the Release cadidate for v5.3.1 of Neo 4k and I am getting normal sound.
Leo
Leo Baker is offline   Reply
