First Light - BUG - copy/paste at DVinfo.net
CineForm Software Showcase
Old December 17th, 2010, 12:04 PM   #1
20 clips in my bin
1. Local Tools turned on for histo/RGB parade.
2. Color corrected all the clips individually with keyframes for primaries.
-2a. about to render/bake in corrections from After effects, need to remove tools.-
3. chose 1 clip, turned OFF local tools (removed histo/RGB parade)
4. SHIFT copy on clip 1, selected to only copy tools.
5. selected all clips pasted on all clips (not SHIFT pasted).
6. all clips took on ALL the properties of clip 1, keyframes, everything.. even though i chose to only copy the tools.
7. 4 hours of color correction had to be redone, as when I hit UNDO, it would not undo the paste command.
8. Cursed, calmed down, restarted my color correction. Called client, pushed them back a day.
bug, or did I do something wrong?
I will only use the SHIFT paste command, and ignore the SHIFT copy selection options.
UNDO seems to be a little temperamental with keyframes.
Justin Lovell
cinematographer//8mm.16mm>HD.transfers . www.framediscreet.com
Justin Lovell is offline   Reply
