quick question on converting at DVinfo.net
CineForm Software Showcase
Old November 8th, 2010, 01:07 PM   #1
I'm about to start a SD project in Premiere Pro - using SD and HDV footage. Is it advantagous to convert both the SD and the HDV to the Cineform intemediate format? or just the HDV?
thank you!
Robert Bobson is offline   Reply With Quote
Old November 8th, 2010, 01:29 PM   #2
One advantage you would gain is a 4:2:2 color space which would be helpful if you are doing color keying work. Other than that, I am guessing there would not be an advantage.
Wesley Cardone
www.WCardoneProductions.com, Detroit and Lansing, Michigan
Wesley Cardone is offline   Reply
