Cineform Capture - Best options for FX1000? Suggestions? at DVinfo.net
CineForm Software Showcase
Old October 12th, 2010, 01:55 PM   #1
Hey there FX1000 Fans!
Haven't posted for a while, but here's the deal. Got a smokin' fast I7 Core (930) computer but still hate the drag on the system when viewing video during the editing process. Everything's choppy with each effect I am overlaying via my native .m2t files. SO - Splurge and get Cineform I'm told. Well, I got the demo and I'm pretty impressed overall (only 4 days left!). But what I'd like to know is, what are the best/ideal capturing options as per the FX1000 (which I would then scoop back into Vegas for editing)?
I see that you can opt for HQ (duh...figure that's best).
I-frames only...checked or unchecked?
Output Frame Format: Maintain Source Frame Format? Progressive Source? Deinterlaced? (Checked or unchecked)
I don't necessarily want to convert to 24p, but do like the option. Ideally, I want movement to look as good as possible (panning in say a nature video shot). I understand 30p IS WHAT CINEFORM uses when the 24p option isn't chosen?
LASTLY: Do I want to capture the audio using CINEFORM too or just the video?
Please and thanks SO MUCH for any of your great thoughts and recommendations in this regard: Makes my purchasing decision more validated when I know what turns other users cranks.
Looking forward to your responses.
Martin Bannet
Martin Bannet is offline   Reply With Quote
Old October 13th, 2010, 03:48 PM   #2
CTO, CineForm Inc.
I-frames only - check.
Depends on want you want to do. Generally leave alone, unless you want to deinterlace 60i source for a progressive output.
CineForm is what every format you want, not just 30 or 24p.
Audio is left as is.
Old October 14th, 2010, 12:12 AM   #3
Thank You!
I guess I should do a tutorial search for NeoScene. But I think I get it. Have done some conversion experiments and definitely DON'T like the 24p conversion/capture look.
I think the fact that TV broadcasts in 60i (right?) and that the film camera shoots in the same format - I shouldn't convert to Progressive even if I am burning a Blu-Ray of things (which I've yet to try). Lots to learn, but thank you!
Martin Bannet
