Update neoscene question at DVinfo.net
CineForm Software Showcase
Old October 12th, 2010, 09:23 AM   #1
I currently have Neoscene version 5.07, now I would like to update neoscene version 5.2. I don't want to do anything until I got a clear answer how it done because I ocassionally see people update their Neoscene and then having licensing problem.
I am thinking install the new version 5.2 over the old one???? is that a go?
Bruce Phung is offline   Reply With Quote
Old October 12th, 2010, 10:15 AM   #2
CTO, CineForm Inc.
Licensing issue may only occur you are moving major versions (like 4.x to 5.x,) or you deactivate when you shouldn't. In either case a trouble ticket with support will fix it. Moving from 5.07 and 5.2 uses the same license, just uninstall the old and reinstall the new. I do this nearly everyday as put of my testing, no licensing issue.
Old October 12th, 2010, 10:48 AM   #3
David.
Unfortunately I won't be able to give you feedback on PP2 within a useful time. I had forgotten I had not sought a new activation code for Prospect 2K after the re-install and it is has lapsed. Have doing my short camera tests in desktop mode. Needs a new computer. I'll get around to it but am juggling the too few dollars and cents right now.
Old October 12th, 2010, 10:59 AM   #4
It done. All good, thank you. From now on I am not afraid to update any new version of neoscene.
Old October 12th, 2010, 11:19 AM   #5
What are the steps to upgrade? And will Neoscene work on Nanoflash files?
Ron Little is offline   Reply With Quote
Old October 12th, 2010, 11:37 AM   #6
This might be a stupid question but why and when do you deactivate neoscene?
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old October 12th, 2010, 05:54 PM   #7
CTO, CineForm Inc.
No, Nanoflash used a high bit-rate high profile MXF MPEG2, that support is in NeoHD and above. NeoScene is desgined for HDV (stand profile MPEG2) and AVCHD (H.264) sources only.
Old October 12th, 2010, 05:56 PM   #8
CTO, CineForm Inc.
Stelios
When moving a license to a new PC, or reinstalling a fresh OS (like a new PC.) Either case deactivate first, when on the new system activate like the product is new,
Old October 16th, 2010, 07:46 PM   #9
Hi Dave,
When I was using Neoscene version 5.07 and everything work fine. Few days ago I update to version 5.2 and now I got NO audio... Whats up with that??
PS, I did reinstall AC3 filter and still NO audio on converted video.
Old October 16th, 2010, 08:10 PM   #10
CTO, CineForm Inc.
We didn't change audio support in anyway that I know of, and it is still work for all the source I've started. Support will likely have the answer, so please file a trouble ticket.
Old October 16th, 2010, 08:17 PM   #11
can you post the supoort link here please.
Old October 16th, 2010, 08:27 PM   #12
CTO, CineForm Inc.
It is on the front page of cineform.com under support.
Old October 16th, 2010, 08:32 PM   #13
Yup. Just submitted the ticket.
