firstlight MAC - Tools not appearing at DVinfo.net
CineForm Software Showcase
Old October 5th, 2010, 01:17 AM   #1
I cannot get the histograms to appear in neo4k FL on a mac.
Is there a step by step you can give me, or is there just a bug to not allow use of histograms??
Justin Lovell
cinematographer//8mm.16mm>HD.transfers . www.framediscreet.com
Justin Lovell is offline   Reply With Quote
Old October 5th, 2010, 08:34 AM   #2
Hi Justin,
I just went and checked on my system. I just updated to the latest build two days ago. I tried the histogram , waveform and all the other tools. None of them are working for me either.
In the past I could get them working by enabling "overlays" and "tools" but now that method is not working.
-John
John Reeve is offline   Reply With Quote
Old October 5th, 2010, 08:38 AM   #3
CTO, CineForm Inc.
You select '+' to add the tools you want in the passive metadata tab?
Old October 5th, 2010, 10:10 AM   #4
Yes I've selected '+' for all the tools individually. I tried moving them around and resizing them but none of them show up.
Old October 5th, 2010, 10:22 AM   #5
CTO, CineForm Inc.
Switch source clips, this will force a refresh -- it works here on my Mac and I'm not a Mac user (they normal hate working for me.)
Old October 5th, 2010, 11:20 AM   #6
Hi Dave,
Just tried your suggestion but still no histogram.
-John
Old October 5th, 2010, 12:13 PM   #7
CTO, CineForm Inc.
Histogram, waveform and vectorscope all working here. There are some refresh issues we are working on. In addition to switching clips to refresh, also refresh the Override Path within the CineForm system perferences. Under the process tab (CineForm prefs), change the override path slightly and then change it back, click OK. See if the controls now work.
Old October 5th, 2010, 03:49 PM   #8
Passive metadata overlays are also not for me on Mac Neo 4K (both Firstlight & Firstlight 5 Beta)
Have tried switching clips and changing the over ride path (& back again) but has made no difference.
Lighting Cameraman - www.rotahead.com.au
Sony PMW-350, FS7, JVC LS300, BMPCC, BMPC, GH5 & a shed full of lights,dollies, jibs
Rohan Dadswell is offline   Reply With Quote
Old October 5th, 2010, 05:01 PM   #9
It seems that you need to enable both tools and overlays to get the tools to show, then you can disable overlays and the tools will operate independently.
Tools and overlays only work on Snow Leopard (10.6) or later. We rely on a graphics library for everything that only ships with 10.6. An earlier version of the codec with simpler tools - just histogram, did work in 10.5.
After changing the override path in the system prefs, you need to restart FirstLight.
Craig Davidson is offline   Reply With Quote
Old October 5th, 2010, 05:18 PM   #10
This method used to work for me in version 5.0.20.xxx ever since upgrading to 5.0.21.xxx the above method does not work anymore.
I just tried refreshing the override path, as well as a fresh reboot of FL. Then activated overlays and tools but still can not add any waveforms or vector scopes.
I am opening a bug report with support now...
Old October 11th, 2010, 11:21 AM   #11
Has a solution been found?
Justin Lovell
Old October 12th, 2010, 11:27 PM   #12
Just installed the latest version v5.0.22 b153 but still no overlays of tools or other passive metadata on my mac book pro. It all worked a few versions ago.
Old October 13th, 2010, 02:08 PM   #13
The stereo mode menu widget is not using the new default path for the override file to enable the tools. Change the location of the override file in the system preference panel and the tools should work. 5.0.23.154 fixes this problem (later today).
Old October 26th, 2010, 06:47 PM   #14
Version 5.0.3.56 - Still can't get the passive metadata to show up in Firstlight.
Have tried changing location of override, no difference.
Old October 26th, 2010, 07:00 PM   #15
still no luck for me with the passive data /tools on a mac.
Justin Lovell
