Does Apple Color work with Cineform MOV?
Does Apple Color work with Cineform MOV? I heard it didn't last year.
If not, can I color correct in Final Cut? Or is first light the only way to do it? |
CTO, CineForm Inc.
Apple Color doesn't support any QuickTime base codecs. You can color correct CineForm files anywhere else, including FCP and FirstLight.
David Newman -- web: www.gopro.com blog: cineform.blogspot.com -- twitter: twitter.com/David_Newman |
"Apple Color doesn't support any QuickTime base codecs."
David, Perhaps you could provide a further explanation of what you mean by this. The Color manual notes a number of Quicktime codecs that are supported for import, and a subset of these that are supported for output. I generally output to ProRes, which last time I looked was a Quicktime codec. Thanks, Kevin |
CTO, CineForm Inc.
Not via QuickTime, no QuickTime based codec works. Apple Color has compiled in Apple only codec support, not third parties compressors can use it.
#5 |
If you want to use color for finishing on the Mac, you can export an XML of your timeline from FCP and import it into ReMaster to create a selection of DPX files. Color understands DPX.
#6 |
I'm so freakin' confused.
Maybe there's someone out there in LA that can color correct this for me in first light? (and just email back the metadata) if so, give me a call and name your price 424-208-9450 |
